Join us on Facebook: Search for 'ConcoursMustang' Private group!
I checked the connection. Nothing loosened. And I even grinded (sandpaper) some areas to make sure having 100% connection (earth).No success.Seems to be I need to change complete wiring starting from bulb cylinder down to connector plug in (2 pins)?
swap bulbs with the one that is working to see I the problem moves or not. this is an easy bulb check.check the bulb socket "tulip leaves" (for lack of a technical term) that ground to the bulb assembly housing, make sure they are getting a good connection.you can take a piece of wire and temporarily by hand touch a known good ground on one end and one of the socket "tulip leaves" to see if it starts working. If it does you know that the supply side and bulb are good and you have a ground issue.
Another easy test is to turn the turn signals on, then pull the socket and try grounding the tabs to the hood to see if the bulb blinks.Other than a bad ground, as others have mentioned, possible issues with the wiring.
