1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year > 1969 Mustang
PARK and BELTS warning lights
kammertime:
Does anyone have a secret to installing these bezels in the dash ?
If I try to get the bezel flush with the metal dash the light and harness just fall out. There is a step on the bezel that I thought was wedged under one of the prongs but I failed to take pictures before I removed the wiring harness.
7Lscjracer:
Here's an NOS example for pics:
http://www.ebay.com/itm/NOS-Ford-DAP-C9ZZ-10A841-B-69-Boss-429-Mustang-park-brake-warning-lamp-wiring-/182253214203?hash=item2a6f2359fb:g:ZB8AAOSw91NTuG-5&vxp=mtr
Must be something broken on the plastic at the back to just fall off, take a closer look.
Are they hitting something back there when you push them in?
Raven R Code:
I'm having a similar problem. My chrome brake bezel is currently detached from the socket. Not sure how to get them together. Was the bezel glued onto the socket or maybe soldered? If soldered, how would it be done without melting the red lens?
67gtasanjose:
--- Quote from: Raven R Code on September 08, 2017, 11:51:02 AM ---I'm having a similar problem. My chrome brake bezel is currently detached from the socket. Not sure how to get them together. Was the bezel glued onto the socket or maybe soldered? If soldered, how would it be done without melting the red lens?
--- End quote ---
These look to be similar to the 67 Convenience Group lamps I have worked on (using the NOS lamp link above as reference).
FWIW, Scott Drake make replacement bezels & lenses for the later 67-68 style (early 67 is different) and they look very similar.
Attaching was originally staked on (crimped somehow) but I used 2-part epoxy & a toothpick applicator with success for attaching the bezel & lens to the lamp housing.
Raven R Code:
They are not the same as the ones off a '67.
[#] Next page
