Marketplace > Parts for Sale
67 Tilt-Away Column
(1/1)
JeffTepper:
If you are looking to replace a missing or broken column, this is a direct bolt in and functions as it should. It is in great condition with all the difficult to find parts included. It comes complete with the column mounted vacuum motor, the vacuum solenoid, the door pin switch, the relay, the emergency flasher button and escutcheon, turn signal switch and lever, the column mounted pin switch for neutral safety switch, rag joint, and the wiring harnesses needed to connect it up. Vacuum reservoir with a built in check valve not included. You will need vacuum hose to connect the vacuum components together. Asking price is $1100. The column is in San Jose and inspection is welcome. A local pick up would be preferred. If you are out of the area and require delivery, secure packaging, shipping, and insurance will be at your expense.
While not "correct" for '68 and '69, it can be installed in those model year cars as well. This column requires a short shaft steering box.
Thanks for your interest,
Regards, Jeff
