Author Topic: Correct Engine Sticker?  (Read 2294 times)
Offline Ralf
« on: November 26, 2017, 03:06:52 AM »
Hello,
Since my engine sticker is missing what would be the correct numbers for my car 289 2V, C4, 66 Nov?
Examples
66
a)
https://picload.org/view/drcdogpi/enginetag__.jpg.html
67
b)
https://picload.org/view/drcdogpw/enginetag.jpg.html
As I think mine should be than:
289 C (Engine Plant C or W?, how to figure out?) 67  X (e.g 14 change level US) Fomoco
6 K (or L) XXX (e.g. 239A, or 236A, Engine Code?) X
Has no E in between (Emission), because none TE equipment)
Am I right?
How far in advance needs the engine tag dated vs. car build date? 2 to 8 weeks, or even more possible?
Great, if someone can post a picture of the location on this tag.
EDIT:
Found this nice one, great help...
http://www.concoursmustang.com/forum/index.php?topic=8221.new#new
Thank you.
Ralf
« Last Edit: November 30, 2017, 01:09:53 PM by Ralf »
Pictures: https://mustang-cabrio-67.jimdo.com/mustang-1967-impressionen
Re: Correct Engine Sticker?
« Reply #1 on: November 29, 2017, 08:25:43 PM »
Will try and help but a little confused - sure its my error or fault.
Are you looking for info for the aluminum engine tag or the engine ID sticker
Understand your working with a
1967 Convertible 289, C4 Automatic, GTA Nov 30 1966, SJ without a 71 or 72 DSO
As far as a date. Lets start with - Do you have the original engine in the car?  And if so what is the assembly date stamped in the block?
Offline Ralf
« Reply #2 on: November 30, 2017, 03:44:40 AM »
>>> don't think so.
>>> aluminum engine tag
>>> correct so far, but no a true GTA (honestly I had no clue about this one when I bought the car), originally 2V, C-Code, DSO 75
>>> yes, except a rebuild to 4V (intake manifold + holley carb), was done before I bought the car. Here is than the question, engine tag to be stamped original 2V or 4V
>> this I do not know currently (and not sure where to find)  ???
Thanks for your help.
Ralf
« Last Edit: November 30, 2017, 01:11:22 PM by Ralf »
« Reply #3 on: November 30, 2017, 06:21:14 PM »
Don't know if I helped.  Did you get all of your questions answered ?
Offline Ralf
« Reply #4 on: December 01, 2017, 02:26:54 AM »
What I wanna do, visiting Marti, submitting VIN and see what will be the result.
Offline Building 3
« Reply #5 on: December 01, 2017, 11:47:29 AM »
Ralf: there is a stamped build date on your engine. It is on the left front side. (Driver side)  It is on a flat surface near the water pump and above the fuel pump. So the stamped date and the metal tag need to be consistent. The stamped date is covered in paint so it's first. But what was the delay on putting the tag on? Same day or a few days later? I would think that they would be very close. The engine was assembled, painted and then shipped to the assembly plant.
Offline Ralf
« Reply #6 on: December 01, 2017, 12:03:43 PM »
Thx, I'll check that tomorrow. Do you have a pic?
It's 5 pm, already dark, lights in my garage are to weak to be able to see anything ;)
You're refering to this (its not mine)?
« Last Edit: December 01, 2017, 02:21:05 PM by Ralf »
« Reply #7 on: December 01, 2017, 01:39:40 PM »
Probably. Your picture's file took way to long to load, so here's mine.
Offline Building 3
« Reply #8 on: December 01, 2017, 02:07:30 PM »
Yes. That is the one Ralf needs to find. I had the same problem. His photo never loaded.
Offline Ralf
« Reply #9 on: December 01, 2017, 02:18:01 PM »
Modified the above one.
Nevertheless, used flickr now.
The photo I loaded:
https://www.flickr.com/photos/157759092@N02/23904091517/in/dateposted-public/
I took a photo of mine....problem.
https://www.flickr.com/photos/157759092@N02/38737657042/in/dateposted-public/
« Last Edit: December 01, 2017, 02:21:51 PM by Ralf »
Offline Deuce
« Reply #10 on: December 01, 2017, 03:12:16 PM »
At least on my car, the machined pad surface with stamped engine assembly date is obstructed from view by the AC compressor and brackets at the left front of the engine block  Other than by removing the compressor and brackets, haven’t figured out a way to clearly see the stamping.
Deuce
2008 Premium GT Coupe, 5-speed, rear spoiler delete, HID headlamps, well-optioned, Flat Rock built Oct 23 2007, RC 72
Offline Ralf
« Reply #11 on: December 01, 2017, 03:14:54 PM »
Clear, this is what I meant with "problem" as you can see on my picture.
Offline Deuce
« Reply #12 on: December 01, 2017, 04:08:13 PM »
Ralf,
Your car and my car were built at SJ assembly plant on the same day; November 30 1966.  My car is Thermactor equipped since it was invoiced to a dealer in the Los Angeles area (DSO 71).
My engine tag:
289 E 67 FoMoCo
L F 236-B 15
The E in top line is the Windsor plant designation (not “emissions”).  The L in the bottom line is date code for November.  I think the jury is still out on what the F signifies in the bottom line, with no consensus.
Deuce
Offline Ralf
« Reply #13 on: December 01, 2017, 04:55:57 PM »
Oh...nice one, same car build. May be we could share some pics.
I meant the E in the second row as "emission", not in the first row. ;)
Example
First row
289 E 67 Fomoco
C= Cleveland, W= Windor, E= Windsor
Second Row
6L E 239-A 14
6 = 66, L= November, E = could be emission (but you have an F, which is indeed in the contrary what has been said in other threads) 239 - A 14
Offline Deuce
« Reply #14 on: December 01, 2017, 05:48:51 PM »
Since your car is a C-code 289 with C4 automatic trans, second line on the tag would be something like:
L (F or ?) 236-B 15
236: C-code w/automatic trans
-B 15 {consistent with Level 15 Windsor 289 engine produced from mid-11/66}
F remains an unknown designation as far as I know.   Some have speculated it’s related to whether or not the engine has Thermactor system installed.
Another clue to help narrow things down would be to identify the engine block casting number and casting date.
(some of the above info is researched from the Manell book)
« Last Edit: December 01, 2017, 06:11:36 PM by Deuce »
Deuce
