Author Topic: Vacuum to power brakes and automatic transmission  (Read 1395 times)
Offline momsmustang
« on: February 15, 2017, 09:33:32 AM »
I have a 1966 mustang with a 289 engine, power brakes and power steering. Currently both the metal line to the power brakes and the metal line to the transmission are connected to a fitting in the rear of the intake manifold. Looking in Bob Mannel's engine book he states on cars with both power brakes and automatic transmission there is a single line off the intake manifold that goes to the power brake booster and a special fitting is used at the booster to connect the vacuum line to the transmission.
Does anyone have some information such as a picture and part number?
That begs the question as to why a fitting exists for the intake manifold to connect 2 hard lines.
Thanks for the assistance.
Offline markb0729
  • South Jersey
Re: Vacuum to power brakes and automatic transmission
« Reply #1 on: February 15, 2017, 10:14:33 AM »
I just went through a similar situation with my 65 Fastback.  One fitting is used for the hard line connections to the intake manifold.  This post should help.
http://www.concoursmustang.com/forum/index.php?topic=15280.msg95359#msg95359
I can't confirm if the 66 connections are the same though.  Maybe others will chime in.
Edit: The guy on ebay still has a fitting available if you need it.  Its not cheap, $40.
http://www.ebay.com/itm/65-66-V8-289-mustang-Brass-Vacuum-intake-fitting-For-Power-Brake-/252760083348?hash=item3ad9accb94:g:sssAAOSw5cNYmkmi&vxp=mtr
« Last Edit: February 15, 2017, 10:28:03 AM by markb0729 »
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
