Restoring - General discussions that span across many different groups of years and models > Parts
OEM Dashpot + bracket + nut + screw Autolite 2100/4100
(1/1)
Deuce:
--- Quote from: J_Speegle on February 15, 2018, 08:15:56 PM ---Might be a good question to start a thread with up in another section of the site rather than an add on discussion to a WANTED ad
--- End quote ---
Per Jeff's suggestion, starting a new thread here in the Parts section.
The discussion has been about the small block OEM dashpot used in Mustang year models 64-66 and 67.
Relevant quotes from the original thread:
--- Quote from: Ralf on February 12, 2018, 02:09:10 AM ---Hi,
I'm looking for a working OEM dashpot + bracket (+ nut + screw) Autolite 2100/4100 carburetor.
Car: Nov 66.
Thx.
Ralf
--- End quote ---
--- Quote from: Ralf on February 12, 2018, 01:26:22 PM ---Not sure if I need to have the bracket without spring hole. I believe so, because of the early build of my car.
Later versions do have the hole and the spring, but no clue for what reason..... ::)
--- End quote ---
--- Quote from: 67gtasanjose on February 12, 2018, 01:28:16 PM ---hole for spring is a passing gear item NOT used on a 67-down Mustang. It was used on other Ford cars & trucks with Auto Trans in 67.
--- End quote ---
--- Quote from: jwc66k on February 14, 2018, 12:49:51 PM ---The question was if there was a hole or no hole on "early" (I assume 64-66) brackets for Mustangs. The application and use is interesting but really does not apply.
Back to the question - is there a different dashpot bracket without an additional hole that was used on 64-66 small block Mustangs?
--- End quote ---
Ralf indicated above that he's not sure whether his Dashpot bracket should be with or without the spring hole.
So... I can add: Ralf's car and my car were both built at the San Jose plant on the same day, November 30 1966. My Autolite 2100 carburetor C7DF-V with date stamp 6LC on brass tag has the Dashpot bracket with the spring hole; however, there is no spring present.
67350#1242:
--- Quote ---So... I can add: Ralf's car and my car were both built at the San Jose plant on the same day, November 30 1966. My Autolite 2100 carburetor C7DF-V with date stamp 6LC on brass tag has the Dashpot bracket with the spring hole; however, there is no spring present
--- End quote ---
I have an unmolested C6ZF-E Autolite 4100 4V with brass tag and spring hole in the bracket. Date code B 6BA.
Deuce:
--- Quote from: 67350#1242 on February 17, 2018, 10:14:28 AM ---I have an unmolested C6ZF-E Autolite 4100 4V with brass tag and spring hole in the bracket. Date code B 6BA.
--- End quote ---
Too early to arrive at any conclusions; but here we have one example that the 2100/4100 dashpot bracket with spring hole was produced as early as February 1966 (6BA).
