Author Topic: 1967 SJ A Code Autolite 4100 disassembly  (Read 1299 times)
Offline redlinetom
« on: November 10, 2012, 10:58:25 PM »
I'm trying to pull the top of my carb off to replace the accelerator pump.  I see 11 Phillips head screws and have removed those along with disengaging the linkages.  Seems like it should come apart at this point.   What have I missed?   :-\
Offline JKWilson
Re: 1967 SJ A Code Autolite 4100 disassembly
« Reply #1 on: November 10, 2012, 11:23:27 PM »
Did you take out the center stud for the air cleaner? It also holds the top. ;)
Offline redlinetom
« Reply #3 on: November 11, 2012, 10:10:15 AM »
 ???  Dooh!!!   The center stud..   I knew that, yet tonight it was way too obvious for me to see.   ;D   Thank you JKWilson.
Thanks also to jwc66k for the instructions.   I have the more square version with the pump on top, but I'm sure there are similarities here that will be useful.  I appreciate your kind responses.
Offline JKWilson
« Reply #4 on: November 11, 2012, 11:06:27 AM »
You're quit welcome. Even knowing it has to come out in order to disassemble, I've forgotten to remove it in the past and had to stop and wonder what the heck!   ;D
