1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: jgkurz on August 24, 2017, 05:57:09 PM
Hi Folks,
I have a quick question regarding the routing of my battery ground cable. My car is a 1969 Mach1 Q Code 428CJ/C6 built in Dearborn on Feb 5, 69.
Should run run the ground cable over the top of the battery then down to the engine mount or from the ground post then beside the battery down to the engine mount? How was it done by Ford?
Thank you,
I vote for beside the battery. Maybe there are some "period" photos around that would provide a definitive answer.
I have looked for old pics but so far haven't found any of that particular area. I am hoping beside the is answer as well. :)
If it should be beside then which side? fender side or radiator side? These newer restoration pics show the cable beside the fender.
(https://assets.hemmings.com/story_image/41357-500-0.jpg)
(http://image.mustangandfords.com/f/35545279+w650+h650+cr1+st0/mump-1112-01-how-to-troubleshoot-your-charging-system.jpg)
http://www.concoursmustang.com/forum/index.php?topic=271.msg87225#msg87225 I also ran the neg. cable through the lower ' D ' Bracket before grounding to the block. Brian
Two different power and ground terminal locations on the batteries?
Thank you Brian. Your post from 2016 was just what I needed.
This should help. Regular production line car from 1969. Almost forgot I had these until you asked the question
Way I remember them and have run them
Hope they help
(http://www.concoursmustang.com/forum/gallery/8/6-240817212339-81841662.jpeg)
(http://www.concoursmustang.com/forum/gallery/8/6-240817212341-81861087.jpeg)
While we are talking about the battery ground cable I have another question. I have seen the battery ground cable connected in two spots. Some are to the engine mount stud and some are bolted to the block behind the alternator. Which is correct? My Osborne manual seems to show battery ground connected directly to the block.
(https://farm5.staticflickr.com/4381/35987461003_261b04bd9e_z.jpg)
(https://flic.kr/p/WQ69nz)
I would think the engine mount "stud" (?) location would be an attachment made in haste due to a lost ground bolt.
I did mine to the block.
Here's some cable routing posts.
http://www.concoursmustang.com/forum/index.php?topic=3154.0
Brian has a shot of his in this post.
https://www.428cobrajet.org/forum/index.php?topic=22787.0
Goes to the block - the reason the stud is designed for like other Ford engines.
To the motor mount is just someones shade tree fix or easy way
Thank you. Hoping to get the car running this weekend!
Hope they help
Thank you Jeff. Those two pictures seem to depict, accurately, the correct battery cable installation. Brian
Lets hope so - that's the goal ;)
Interestingly (a subject for another thread) the difference in the hold downs. Wonder if Dearborn and other plants had a running change during the year. Or maybe I just missed that class or some other detail has pushed it out of my memory LOL
The photo with the 70 dodb plastic hold down bracket could be a early70 cj car ?
Here is a wider look at the same picture from the magazine. Looks to be 69 style shock towers but what do you think?
(http://www.concoursmustang.com/forum/gallery/8/6-290817161755-8587514.jpeg)
Looking at where the horns are located it would seem to be SCJ car ? Missing the oil cooler, using wing nuts on the air cleaner, corner of the forward-upper right C9 valve cover is missing ? The service decal on my Metuchen car is vertical. This one appears horizontal. Maybe a clue there ? The only hint that it might be a 70 are the shock tower braces. I can barely make out the extra bracing at the firewall side ? Gotta squint real hard. Brian
Lack of hood pins is my first wonderment as well as the moved and no cooler(just like 69 Boss 302s) There does seem to be a depression in the rubber radiator seal around the passenger side hole
Inspection stickers suggest Dearborn as well as the stapled on radiator seal. The 69s also used had the reinforced shock tower braces
Not sure what your seeing when you refer to the valve cover is missing.
69 style shock tower braces, later cast 69 - 70 valve cover style
Being a magazine car could explain the wing nuts on the top section of the shaker. So "fine tuning" of these cars was the nor to get better reviews by the writers ;)
The valve broken cover is a smog pump hose super imposed ? Any clues with the battery heat shield or no ' caution ' on the radiator shroud? Brian
Looks like the bottom cover may have been bumped - just needs to be pushed up and reseated
Don't see anything that would indicate that. Touching up pictures at the time would not be the norm for a car magazine
Heat shield has the bump up lip, it appears) on the long end suggesting that its a C7 (correct for up to 69) rather than the 70. The CAUTION FAN sticker would have been installed if the car had been serviced after 1971 at a dealership or the owner applied one after receiving a letter n the mail from Ford in 1972 or replaced the shroud with a service replacement boxed after 1971 (still had to take the sticker and stick it on the shroud in the early versions) .
Not a factory decal placed on new cars other than Boss 429s with the open (very small in comparison) finger guard
No ' Cobra Jet ' on the shaker scoop ? Just an observation. That hose coming off the air cleaner base, right side, and going down behind the snorkel and heat riser is what ? Brian
............. That hose coming off the air cleaner base, right side, and going down behind the snorkel and heat riser is what ? Brian
That would be a hose for the vapor recovery system (California thing in 70
Picture is a confusion or mix. Possibly an engineering or test car for multiple 70 features that was released to the media
Wish I had a copy of the complete article to at least have a time frame and some context to measure things by - even though you can't believe what was in print ::)
That would be a hose for the vapor recovery system (California thing in 70)
Ding!, that is what I was thinking. California 1970 paper tube, going to charcoal canister. Would also say it is an automatic car, based on vacuum advance.
Would a 69 GT350 battery ground rout the same way?
If you mean outside of the hold down bracket then yes. You can see much else that would apply in the pictures. A better illustrated routing for the 351W is in the electrical manual of the assemblyline manual set.
