Restoring - General discussions that span across many different groups of years and models => Body, Paint & Sealers => Topic started by: Adwear on January 31, 2017, 09:25:34 PM
Title: What is the best undercoat?
Post by: Adwear on January 31, 2017, 09:25:34 PM
Restoring a 70 Boss 302. What is the best sound deadener / body schultz to use for the front wheel well area and engine compartment? Looking for a spray type. Any suggestions?
Thank you,
Bob
Title: Re: What is the best undercoat?
Post by: J_Speegle on January 31, 2017, 10:52:28 PM
Bob   will just copy and paste what I posted on the other site ;)
Getting something close to the original finish is a combination of a good product and a good technique. Most find it helpful to do allot of practice of vertical panels (cardboard boxes will work in many cases) - of course with some of these products that may cost a bit but getting it right and not having to correct it later should be the goal.
What your going to need is first examples from the original car so that you can identify the original pattern and where it was applied, allot of the cars had some of the main floor pans coated also.
Products that seem popular when this subject comes up in recent years have been Lord Fusor and SecondSkin/Spectum Sludge. The later will need an top coat often to tint the final look correctly in areas where its not covered with body color (example rear wheel well and trunk)
Both will allow you to build the thickness up to 1/4" - up thickness and the sagging curtain look of some original examples
Lord Fusion comes in fairly small chalking tubes while Sludge can be purchased in a 1 gallon tub, its two part
If you do a search you'll find pictures, opinions and experiences from members in past threads. Let us know if we can help more.
