1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: TLea on February 23, 2017, 01:58:58 PM
Looking for correct engineering numbers for distributor and carb for Metuchen built 67 390 GT 4 spd. No AC, thermactor or PS. Late May 67 build
Try the library.
Thanks Jim. I have references from Ford manuals. As we know that isn't always what ended up in cars. Can someone relay their findings from original cars?
Carb C7OF-9510-A Holley list 3793
Distributor possibly a C7OF-12127-H
After 50 years, you expect original?
If I was a 67 judge, knew my distributors and carburetors, and saw something I knew was not specified, I would be suspicious. The "book" (read any documentation) may be incorrect, but what is found in a car isn't the best method.
On the other hand, if you come up with something different and have a source, I'll be grateful for some input and will update the info I've entered.
I'm not saying ended up as in owner modified but what Ford did. A good example is 68 428 cj distributors. The books show 2 versions, I can name 5 that were used
If true, I would like the Ford numbers, a source and any other info you have.
Thanks for the input Jim but with all due respect I don't have time to write a research paper right now, I just wanted some information
For those reading who this might benefit I have had reported to me from several known original cars a 67 S code 4 speed mustang uses either C7OE A or C. C is thermactor, all others A. The A matches with the C7OE H distributor. The C uses either C7OE F or G
For those reading who this might benefit I have had reported to me from several known original cars a 67 S code 4 speed mustang uses either C7OE A or C. C is thermactor, all others A. The A matches with the C7OE H distributor. The C uses either C7OE F or G You have not seen a C7OF-F for a 67 390 application ?
You have not seen a C7OF-F for a 67 390 application ? Sorry, I do see this in your post.
bringing this thread back up because I just bought a 1967 S-Code Fastback 4 speed.....needed same info
Thanks Tim!
Have you considered using the library on this Forum? It "might" have the information you need there.
Wow Jim.......have not been on here much last couple years but now I know about the library.....thanks thats great stuff!
See your signature shows a Jan 67 build but the other needed piece of info would be Thermactor or without. ;)
If your going to use the Library then you don't need to post it here unless you want us to provide - just sort of a reminder for the next poster
thanks Jeff will add to sig......
