Restoring - General discussions that span across many different groups of years and models => Interior & Trunk => Topic started by: 69eliminator on December 15, 2013, 06:42:18 PM
looking for the finish for the dash frame that is not visible from the interior? is it natural steel? can someone post best way to restore?
thanks
Brian
Yes, natural steel.
Depending on the conditions the car may see after restoration may guide you to a choice during restoration. Of course the your choice on how to clean the rust off also has a bearing on it also since blasting (for example) will leave a finish who's surface texture and color are unlike any natural metal. If you can clean it and return it to a factory look then protecting with a coat of Bo-shield (or similar product will work) after you paint the face like factory. Others would add a coat of stainless steel paint (or one of your likely that reproduces the look of bare metal ) then paint the surface
This basically applies to all mustangs (and cougars ;) no matter if the dash section is removeable or is welded in. Just another challenge
I used Evaporust on my dash and it came out great. You will need a large vat to do it though or know someone who has one.
