Author Topic: rebuilding your alternator  (Read 1031 times)
Offline cobra427
« on: December 18, 2014, 04:03:27 PM »
Has anyone rebuilt your alternator to concours standards.  Mine is it good shape, but I want to clean up the case.  I dont know how I am going to put the Autolight stamp on it.
I was just wondering if anyone has done this?
Gary
« Last Edit: March 19, 2017, 09:45:58 PM by carlite65 »
Currently working on a 68 GT500 #00563  Build date 13 Feb 68 NJ car.
Gary Ross
Re: rebuilding you alternator
« Reply #1 on: December 18, 2014, 05:37:00 PM »
Gary
It can be done . It is not cost efficient to do it one or two times with all that has to be done.  If you WANT to do it for your own experience that is a different story.
Offline cobra427
« Reply #2 on: December 18, 2014, 05:56:10 PM »
I just wanted to keep the original alternator with the car, it worked just fine when I took the car apart, really not much to them, I just dont know how I'm going to put the red Autolite stamp on it.  I was wondering if anyone has ever had a stamp made.
Gary Ross
Offline rockhouse66
« Reply #3 on: December 18, 2014, 06:07:06 PM »
As you may know, you could send it to Jack at deadnutson.com.  You will get your own unit back if that is what you want.
'66 GT FB, '69 CJ Grande
Offline BKnapp
« Reply #4 on: March 19, 2017, 09:30:50 PM »
Just out of curiosity, what is the yellowish coating on the outside of the coil. Is it really just a varnish?
Thanks!
1967 390 Coupe A/T  P/S  P/B. (S.J. Built 1/4/1967)  7R01S145xxx
« Reply #5 on: March 19, 2017, 09:47:21 PM »
Well sort of- it has a scientific name that I can't think of at the moment (someone will goggle and find it) but it's an insulating coating for the windings
« Reply #6 on: March 19, 2017, 11:02:23 PM »
Yes it's a varnish, but also an insulator and very quick drying adhesive that is used to keep each strand of wire in place for maximum voltage and current output. Special winding machines literally throw the wire into place on a form after it goes thru an industrial type alcohol activator. The wire is covered with the varnish from its factory, allowed to dry and wound on spools for use.
Offline Daisy
Re: rebuilding your alternator
« Reply #7 on: March 29, 2017, 02:36:12 PM »
I found Mothers[tm] Aluminum Mag Wheel Polish will clean the alt case very well ;)
If you buy the stamp  - let me know, I would like to borrow it.
Daisy is a 1967 Mustang Coupe
Frost Turquoise
White Vinyl Top
390/C6
« Reply #8 on: March 29, 2017, 04:08:57 PM »
Unfortunately it will not look anything like the original finish    :(
Offline caspian65
« Reply #9 on: March 29, 2017, 04:49:48 PM »
+1, it will be way too shiny if Mother's polish used.
Offline preaction
« Reply #10 on: March 29, 2017, 04:59:58 PM »
Would a vibratory tumbler with ceramic media fit the bill ?
8R02S125064- January 6 1968  SJ   7F93S591808 - April 28 1967  Dearborn   7F91S544039 - December 17 1966 Dearborn
« Reply #11 on: March 29, 2017, 08:49:15 PM »
Don't believe so since aluminum is a soft metal. The challenge is getting it clean while getting a freshly cast look to the cast metal then adding the fresh machined surface to those areas.   Wish I had enough of the same aluminum parts all with the same well used finish that we could try different things on to find a decent process.
Offline preaction
« Reply #12 on: March 29, 2017, 09:33:40 PM »
Jeff, how did you make out with the wet aluminum blasting, I forgot the name of the process.
Offline Daisy
« Reply #13 on: March 30, 2017, 03:53:28 PM »
You would think so - but was not.
You simply wipe on and wipe off.
Frost Turquoise
White Vinyl Top
390/C6
