Non-Mustang Ford & Mercury Models > Mercury Models 1965-73
1969 Mercury Cyclone Engine compartment black out transition
(1/1)
1969 Cale II:
Here are 3 photos, 2 from one car 1 from another. Both are 1969 Mercury Cyclones, original paint cars. The black out transition line is pretty wide, shows the size of the gun pattern. Hope this helps others.
1969 Cale II:
Forgot to point out on the first photo you can see on the white cowl area where the little white stickers were. Too bad I can't tell which ones they are. Just shows 2 spots. Did not see any others on this car.
J_Speegle:
--- Quote from: 1969 Cale II on May 14, 2016, 07:23:28 PM ---Here are 3 photos, 2 from one car 1 from another. Both are 1969 Mercury Cyclones, original paint cars. The black out transition line is pretty wide, shows the size of the gun pattern. Hope this helps others.
--- End quote ---
Were all 69 Cyclones built at one plant?
Guess I could look it up but its easier to ask you ;)
1969 Cale II:
Yes, all Cyclones were built at Lorain Ohio.
