Restoring - General discussions that span across many different groups of years and models > Suspension
Master Cylinder and Brake Booster Rebuild
Adwear:
Does anyone have a recommendation for a company that rebuilds Master Cylinders and Brake Boosters for my 1970 Boss 302? I am aware of A-1 Cardone, but my concern would be getting my original parts back.
Any feedback would be appreciated
Thank you,
Bob
67gtasanjose:
Booster Dewey has been recommended before.
tobkob:
+1 Booster Dewey did my brake booster and I'm well pleased.
TOB
Adwear:
Any recommendations on Master Cylinder rebuilding?
Bob
67gtasanjose:
--- Quote from: Adwear on September 30, 2016, 12:08:13 AM ---Any recommendations on Master Cylinder rebuilding?
Bob
--- End quote ---
If you have your original cylinder, you might consider this as a do-it-yourself job. Kits are available at Napa stores etc. Not much involved and as long as you know how to seat the forward-most piston on front side of the center stop bolt (center stop bolt is not used on later designs), very little could go wrong. Lubricate the seals with the kind of brake fluid you intend to use and assure yourself the seals are installed facing the correct directions (note this upon disassembly) and most 8-year-olds could do this job ;)
[#] Next page
