1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year > 1969 Mustang
Numbers matching seats. Who knew?
(1/1)
Cigarwilki:
So I'm surprised to have found aluminum tags on the bottoms of all my seats while looking for a build sheet. I guess it's a thing. Surprised I never heard of it!
Is it common? Thoughts?
Cigarwilki:
Image 3
J_Speegle:
"Who knew?" Members that have been here for a while and many owners ;)
Just a label/tag that identified the frame and springs used by the supplier. Not a Ford thing.
If you check the search feature this has been discussed a number of times for other years including a period when these were made out of a cardboard material
jwc66k:
Keeping with Jeff's consistent question - what plant? The San Jose assembly plant used a seat frame company located in the Los Angeles area and I've seen more paper tags on early (64-67) seats from them.
When I rebuild a seat I make it a point to reuse the tags with a new hog ring. I guess that's why I can't find any seat tags in the "tag heaven" container.
I do have a 3 3/4 X 1 7/8 paper tag with part number "C4ZB 6563810 A", "Quantity 100", "badge no 40", date "blank", from the "Young Spring & Wire Corp. Archbold, Ohio". The base number "63810" does not appear in either the illustrated or part number section so I assume that "63810" is a sub-component part of a seat, probably the frame. Ford service sold partially completed seats, frames were assembled. The tag is now a novelty. It exists but what it identifies is unknown.
Cigarwilki:
Very interesting though Jim. Thanks for the note. My car is from the Metuchen New Jersey plane. It was assembled June 13th 1969.
