1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year > 1967 Mustang
1967 Mustang w/Big Block what finish are the block plates for the engine mounts
(1/1)
motor head 428:
What finish are the block plates that bolt to the engine, that the motor mounts attach to.And the finish for the attaching bolts. For a Big Block Engine in a 1967 Mustang. Thank You
Bob Gaines:
--- Quote from: motor head 428 on June 23, 2017, 08:23:58 PM ---What finish are the block plates that bolt to the engine, that the motor mounts attach to.And the finish for the attaching bolts. For a Big Block Engine in a 1967 Mustang. Thank You
--- End quote ---
Bare steel on the brackets that bolt to the block. I would use P/O on the bolt ,light P/O on the washer and zinc silver on the nut. You need to protect the bare steel brackets against rust. I use T9 Boe Shield.
motor head 428:
Thank You, Bob
