Author Topic: Another addition to the stable - 66 NJ V8  (Read 1103 times)
Offline Hipo giddyup
Re: Another addition to the stable - 66 NJ V8
« Reply #15 on: September 05, 2017, 12:37:11 PM »
 I do not think any rust has passed to the underside. Luckily it looked like just surface rust. The headliner and window gaskets are in great shape and fairly new so I will roll the dice and hope no issues down the road.
 As to Jeff's question, I scuffed over the encapsulator surface to allow the short strand fiberglass filler the ability to adhere. I have since put a few thin coats of filler over the areas and will sand most of it off. Then I intend to use a top coat filler , again in thin coats, to smooth things out before the primer. The encapsulator reminds me of the PPG epoxy primers in that it tends to ball up when sanded. Just with the epoxy primers, they need scuffed after so many days before any type of top coat goes over them. The roof had not dents or filler anywhere so I am really just killing the rust and filling the tiny craters left from the oxidation (and to prevent any more outbreaks). I will have very little filler left on the roof when I am finished but this will be necessary to get it ready for paint.
I also checked the Eastwood website and they followed this same procedure when repairing a pitted fender..  Sand to bare metal, rust kill the pitted area, fill with Encapsulator, sand off leaving encapsulator in the filled - pitted areas, filler and prime.
I hope to have a few more photos over the next week or so. Once I get the roof primed it will be new tires and tags.  ;D
« Reply #16 on: September 13, 2017, 04:04:12 PM »
Here are some recent pics of removing rust from the trunk lid. I did use rust encapsulator inside the trunk lid before I welded the new patch in place. ;)
« Reply #17 on: September 13, 2017, 04:05:48 PM »
 Overall pics of primer/sealer on the roof.
« Reply #18 on: October 24, 2017, 11:42:01 AM »
Here are some pics of repainting the styled wheels on this car. First I did a good cleaning followed by stripping off the old argent paint. Next was more cleaning using some steel wool, and then the lengthy process of taping. I used the rolled tape method so as not to get a sharp paint line (you can see gaps under the tape around the borders).  Light coats of the argent paint worked well here. I used some self etching primer to help the argent paint stick, before finally applied the argent paint itself. Since my intent is to drive this car I will not be going with bias ply tires. The procedure worked out great for restoring the original 66' styled wheels.
« Reply #19 on: October 24, 2017, 11:42:44 AM »
Here's the final result.
« Reply #20 on: January 11, 2018, 11:44:40 AM »
 Haven't been so lucky lately with this build. After putting a few hundred ,miles on the car I kept noticing that it was continually blowing out antifreeze through the overflow hose. So much so that there was no antifreeze covering the cooling vents inside the radiator.  I became worried about a bad head gasket so I let the car warm up and removed the radiator cap. After a few seconds I noticed many bubbles and belches or air coming through the system. My gut was telling me that there must be a small connection between a cylinder and a water passage in the head gasket. I decided to replace the intake and head gaskets for piece of mind. Now this car has only about 8K miles on a full rebuild but it has sat a lot of this time over the past 15 years or so. It never ran rough and never had any instance of coolant on any of the plugs. Perhaps this was an issue that was just starting?
I was lucky enough to have to only cut one nut off of the exhaust stud and everything else was able to be removed without issue. I cleaned and checked the heads and there was no visible issues or cracks that I could see. The head gasket didn't really look too bad but then again some of it was destroyed by removing it. So new heads gaskets and intake gaskets were replaced and everything ran well and was going well until I noticed a small puddle of coolant on the passenger floor mat. Now I found that the original (and even date correct ) heater core for this car was now giving up. The following weekend I removed the restored heater box and replaced the heater core. Now I think I finally have things under control.
I also installed an overflow tank just to be sure the coolant level stays where the engine likes it. So far everything is working great and it's turning into a very nice driver!
After all of this, I also ended up replacing the C4 pan gasket , replacing the tranny fluid (again), and replaced the shifter shaft seal that had been leaking. That was something I had discussed here under the drivetrain section if interested in that discussion. Next I plan to start on the body work this spring and hopefully will have it painted before summer.
