Restoring - General discussions that span across many different groups of years and models => Drivetrain => Topic started by: Sunlitgold68 on August 10, 2009, 01:03:59 PM
Title: Radiator Fittings
Post by: Sunlitgold68 on August 10, 2009, 01:03:59 PM
Do you need to put any sealer around the transmission line fittings where they fit into the radiator. If so can you use the same type white stuff you use around the intake thermostat fittings?
Title: Re: Radiator Fittings
Post by: carlite65 on August 10, 2009, 01:57:07 PM
i use the teflon sealer in a tube made by permatex. very to wipe off the excess that oozes out when installed.
Post by: J_Speegle on August 10, 2009, 11:52:32 PM
You can use anything you like - just make sure you pick or brush out all the extra so the judges can see none of it. And the white stands out allot
