1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: Brian Conway on January 18, 2017, 11:50:14 AM
Got a little curious about these when forum member Armond posted in the ' Parts Wanted " section these photos of originals ? Of course the ones on my 69 don't look like these and I would like to correct that if I can. Measurements of the rods, on my car, reveals that they are 13/16's" round and at the treaded portion they are 11/16's " round. The rubbers in Armonds pictures seem to carry a C8 number and that's about all I can get from the photos. The other photo is of an ebay auction. This, ebay, part has printed instructions on the front, a part number, a solid tube pressed onto the washer and claims to be 11/16's " round ? Any information on this ? Thanks, Brian
Aren't the big washers a big block thing?
Strut rod washers are the same regardless of big block or small block regardless of year.
Here are a few pics. You can see the replacement washers are bigger and came from a D0oz kit. The smaller washers are 69's. The two sleeves are 68/69. I am not sure about 67. I have a couple of cars here with the originals still in-tacked and I don't want to take them off. I needed these for my R code coupe as my originals are pitted. These I found are nice and at the moment just glass beaded. I will Phosphate before used. When you take a original strut rod off you can see that Ford must have used a crimping machine to install the bushings because the thinner aluminum sleeve is crimped around the back washer. I don't have a picture of this unfortunately. The bushings I currently have are marked D0oa and C8oa. I am still looking for two non ribbed C8oa-3A140-A bushings.
I remembered I have a 70 parts car that still has the strut rod bushings still in place. You can see how the front sleeve is crimped against the back sleeve. I think that Ford did this to pre load the bushings so save time when it came to alignment etc.
67 has a slightly different profile when compared with 69 when viewed on edge from what i have seen..
Have never seen washers with markings indicating "this side forward" or similar on original washers but almost always on replacement examples.
Markings on the rubber bushings can be between NOS (service parts) and originals and there may be some variations if more than one supplier was used and in those cases we should find differences between plants (east to west)
Just posted a group of pictures in another thread covering the disassembly (well partical) of my 69 Boss of the original strut rod bushings that might help address some questions so posting a duplicate set of pictures here also - Hope it helps
Face of front strut rod washer and bushing. Seen a few rattle can passes of black paint over its short 30K miles :( But it did protect the finish under the black. You can still make out the blue (often found teal also) peeking out through a chip or two in the black. This end is the thinner end of the long inner liner that is forced over to hold the bushing and washers in place and the easier of the two to rework/remove
(http://www.concoursmustang.com/forum/gallery/6/6-180117152418.jpeg)
Back side of the bushing assembly - more black rattle can
(http://www.concoursmustang.com/forum/gallery/6/6-180117152143.jpeg)
After the lip of the inner steel liner was removed with a careful application of a small grinder and some hand tools the assembly (minus front bushing) reassembled to show the order and direction of each bushing as found on car.
(http://www.concoursmustang.com/forum/gallery/6/6-180117152331.jpeg)
Both longer and shorter inner steel liners together
(http://www.concoursmustang.com/forum/gallery/6/6-180117152216.jpeg)
Just the shorter liner. Notice the small amount of markings on the lip of the liner at the bottom
(http://www.concoursmustang.com/forum/gallery/6/6-180117152259.jpeg)
Front and rear washers (painted is the forward washer) Front washer shows a "flying" F in a circle. This "maker's mark" can be found on washers used on both small and big suspension strut washers built at Dearborn at least
(http://www.concoursmustang.com/forum/gallery/6/6-180117152356.jpeg)
C8OA-3A140B rubber insulator markings
(http://www.concoursmustang.com/forum/gallery/6/6-180117151916.jpeg)
Inverted T and a HOC (possibly supplier) markings
(http://www.concoursmustang.com/forum/gallery/6/6-180117152024.jpeg)
Engineering numbers
(http://www.concoursmustang.com/forum/gallery/6/6-180117152042.jpeg)
C8OA-3A225A rubber insulator markings (bottom most is the original)
(http://www.concoursmustang.com/forum/gallery/6/6-180117152103.jpeg)
(http://www.concoursmustang.com/forum/gallery/6/6-180117152123.jpeg)
Well Ok. The pictures and explanations for the originals are very clear. The ones on my car are most likely the same as the ebay example and I am going to guess are an early aftermarket replacement set. The aftermarket set has the rear washer and tube backwards from the OE examples as well as having the stamped instructions on the fronts. Thanks Brian
Most likely replacements for the reasons you mentioned. I have never gotten a clear understanding for the reverse cupping of the rear washer. It is a common mistake in assemblyline restorations. I never paid much attention given I wasn't going to duplicate the placement. Anyone?
There are 5 different strut rod bushing & washer sets & 4 different strut rods between 67 & 70 depending on the year model & when it was built & suspension changes using different washers & 2 types of sleeves & several different bushings & hardware changes & some kits have mixed parts from other kits.
Re-visiting this topic to ask if there is a correct or approved ' strut rod bushing and washers " repair/restoration assembly available ? I just did the bushings on my 65 with the Drake C4DZ-3A187-A bushings using my OE washers. The 69 washers seem to be more ' cupped ' than the 65's ? The crimped inner tube seems to make this restoration a bit more difficult ? I intend to use the Drake C6OZ-3A187-A bushings. Any comment on their accuracy. Thanks, Brian
Sure we will get a number of comments on this subject
Yes the washers are different as are the bushings and such
When I removed my original strut bushings and replaced them a few years back and I did a few pictures of them side by side with the reproduction I choose at that time
Not sure what they used to make the reproductions from but here are some pictures
(http://www.concoursmustang.com/forum/gallery/9/6-070118195002.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-070118195019.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-070118195034.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-070118195049.jpeg)
Second rubber insulator/bushing As you can see a difference in height or thickness depending on how you have it positioned. Not sure if the consent pressure/compression from being installed deforms the shape over time just comparing the two.
(http://www.concoursmustang.com/forum/gallery/9/6-070118195105.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-070118195119.jpeg)
Markings were different in a couple of ways.
(http://www.concoursmustang.com/forum/gallery/9/6-070118195139.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-070118195152.jpeg)
Found this older thread - but as always things change as far as availability, supply and such
Jack at dead nuts on is right now in the process of reproducing the bushings, the C8OA's and the C6OA's. I am not sure where he is at with the process, I just know some time ago he hooked up with a manufacture using NOS originals to start the process.
In Jeff's 2017 post the #6 photo comment says ' with Flying F'. Doesn't seem evident in any of the other photos ? Will be interesting to see the Dead Nuts On version.
FWIW; the assembly on my car, the one with the backward washer, appear to be the MOOG K8157 model see picture. Brian
Got a Drake reproduction Strut Rod Bushing Kit C6OZ-3A187-AR. Would like to share a couple pictures and get your thoughts ? The washers seem to be decent reproductions with a smooth greyish finish. Looking at and comparing to Jeff's pictures these rubber bushings also look close to authentic. Compression and nut torque will play a part here ? The center pipe/tube is about 2.5" long and may be to short ? No crimping involved. The over all assembly is about 3.5" Brian
what is/was wrong about your original washers? i do not understand the need to replace the washers unless they are damaged. they can be refinished & you will have the proper shape.
I don't have original washers. The washers I do have, on the car, are posted in the earlier discussion and I believe are MOOG aftermarket . I do fortunately have the original hardware. Brian
Got lucky and located a set of OE 69 strut rod large retaining washers. One pair is smooth faced and the other pair has witness marks from a nut. The set up on the car now uses a washer behind the nuts front and rear. Shop diagram shows nuts only no washer ? Smooth retaining washer and smaller nut in rear position and retaining washer w/witness marks and large nut up front ? No washers behind the nuts ? Brian
Just the large retaining washer and the nut just like the illustration.
