1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: Brian Conway on December 30, 2017, 05:37:50 PM
I am putting together a spare rear end and would like to be as correct as possible. Need some help with the ' machined surface ' on the RF-C5AW-4668-C Daytona Pinion Support. Does it paint, is primer color, or does it stay natural ? The rest of the body should be red primer ? The Yoke body is semi-gloss black with the collar zinc oxide ? Bolts are black oxide ? Asking for corrections. Thanks Brian
it is my opinion that machined surfaces always stay bare looking as if they were done yesterday. nice & fresh.
I have always seen the yoke shield a bare steel and not plated silver or painted silver as in the picture.
What I have seen is the part was painted the red oxide color then machined, so yes natural metal. The bolts would be I think phosphate/oil, dark gray/black color. The slinger is natural metal as is the yoke. Was yours painted black already/ Does it look like factory or somebodies handy work? If your lucky you might find some paint marks on the yoke, found some on my Cyclones yoke
http://www.mustangandfords.com/how-to/drivetrain/1703-detailing-and-restoring-the-mustang-9-inch-rear-axle/
Above is a Thoroughbred class how to
http://www.mustangandfords.com/featured-vehicles/mump-1105-1969-ford-mustang-429-restoration/photo-gallery/#/
If you click on the individual photo gallery pics, there's text info pertaining to each one
Great. Appreciate the pictures. Pinion body was painted separate from the N case and will be a shade different Red Primer. The yoke shield, pinion machined surface and probably the yoke itself are bare steel. The snubber bracket is also left bare steel. The bolts ( 5 ) are black zinc dichromate. Observations; the snubber bracket metal does not seem to be prone to rust/corrosion while the machined pinion surface and in particular the Shield are ? Thanks for all the help. Brian
