Author Topic: 1965 San Jose A code Fastback - 10/29/64 Build  (Read 4069 times)
Offline ChrisV289
Re: 1965 San Jose A code Fastback - 10/29/64 Build
« Reply #45 on: April 25, 2017, 03:22:10 PM »
Do you know if there was a blue mark as well on the pump? I think I remember seeing one on the pump before it got rebuilt.
1965 Honey Gold Fastback
« Reply #46 on: April 25, 2017, 11:34:54 PM »
I've got pictures of multiple red marks on a NOS period pump in a kit
Offline caspian65
« Reply #47 on: April 26, 2017, 11:03:04 AM »
I looked for pics and couldn't find any.  I know there were a couple others.  The pump cleaned up nice with the original marks, the insides were rebuilt and reassembled.  This is from the pace car coupe I restored, believe scheduled build date was 29D, Dearborn (obviously).
Offline ChrisV289
« Reply #48 on: April 30, 2017, 10:23:57 PM »
Almost ready for Tucson.
Offline DKutz
« Reply #49 on: April 30, 2017, 11:08:52 PM »
Are the air cleaner stickers correct?  I was told not to se the front sticker, and the autolite sticker on side.  Almost same built time.
Offline ChrisV289
« Reply #50 on: October 14, 2017, 05:56:51 PM »
Finally got the car aligned 5 months after the MCA show in Tucson. I'm sure the before numbers are not pretty.
Offline ChrisV289
« Reply #51 on: October 29, 2017, 02:44:05 PM »
53 years old today. Sitting next to its younger cousin.
Offline rodster
« Reply #52 on: October 31, 2017, 11:19:17 PM »
Very nice... :)
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline ChrisV289
« Reply #53 on: January 26, 2018, 11:02:24 AM »
So while I had the transmission out I took the opportunity to clean more of the undercarriage. Found a spot that was missed when they painted the bottom and some red oxide peeking through near where the transmission is. The color of the undercarriage is very interesting. When I shine a light to it, it almost looks like a dark olive green color. Could be the mixture. I do need to get some paint matched up though as some of it bubbled up and peeled of where the emergency parking brake cables attach. Not sure what that was about.
Offline caspian65
« Reply #54 on: January 26, 2018, 02:29:33 PM »
Could be sealer gray primer, which was typically the final coat before paint.
« Reply #55 on: January 26, 2018, 02:43:54 PM »
I think you may have an area that has a combination of oversprays coming together producing what your seeing. The color is additionally enhanced since its a byproduct of a misting.
I have that on one of my cars where the exterior color misted over the base batch color produces almost a maroon in one area while almost a purple in another (different amounts of overspray and transparency through to the base) but if you remove the over coat its the same base as other areas
Offline ChrisV289
« Reply #56 on: February 06, 2018, 11:09:40 PM »
Since I had the driveshaft out with the transmission rebuild, finally got around to putting the numbers back on the driveshaft.
Offline ChrisV289
« Reply #57 on: February 11, 2018, 11:08:09 PM »
So did some more cleaning underneath the car. I also went to Home Depot and got some color samples to see what best matches. Found a bear paint called black mocha that is very similar. There is also some honey gold speckles as well along with black towards the edge from the pinch weld. Some different lighting below with a drop light and my phone light.
Offline caspian65
« Reply #58 on: February 11, 2018, 11:15:12 PM »
Thanks for sharing.
Start using cardboard or padding on your jack stands so they don't mark up/remove paint.
« Reply #59 on: February 12, 2018, 12:04:41 AM »
Thanks for sharing.
+1 They do make plastic covers for those cast style jack stands. Still can leave a mark if not careful but allot better IMHO than the steel only. Use to use carpet samples that were cut in half in the old days
Think Harbor freight had them at $9 a pr
