Restoring - General discussions that span across many different groups of years and models > Parts
Dual Red Lines
markb0729:
This radial by Coker Tire looks almost like a classic bias ply tire. To bad they don't have a dual redline version... yet.
https://www.cokertire.com/tires/styles/radial-tires/firestone-wide-oval-radial-redlines.html
rockhouse66:
Brian
I don't know where your image came from, but Diamondback Tire in SC will provide dual redlines on any radial tire you choose and will buff off the brand name, etc. for a nice look. In our sizes though, the tire of choice is usually the BFG Radial T/A. There may be a Dunlop alternative.
lancelot66:
Brian,
These are from Diamond Back I ordered in 2006 when I lived down in Ventura, CA. They are 205 70 R 14's. At the time they were called "Supreme Dual Redline Tires". I'm not sure what they offer now days. I've really liked these tires over the years. They've held up really well and they ride nice when we get the car out for the "seasonal ~100 miles" or so they receive these days. The only thing I would ask about if you decide to go this route (agree absolutely non-concours) that they will skin the surface of what they use for the base tire and you lose the DOT information on the redline side of the tire. I ordered another one for the spare about two years after these 4 and it was a Power Cushion tire but only retained the DOT information on the un-touched backside of the tire. If I had known this, I probably wouldn't have purchased the latter one because it doesn't match the other four as it should.
Brian Conway:
Golly... thanks for all the help. It is my understanding that a concourse correct dual redline tire is not available in the after market ? Things change and I could be wrong ? Rockhouse and Lancelot66's using/suggesting Diamond Back is certainly an option. I think the tire I posted is a more affordable, $200 and free shipping, option ? That tire is from Coker # 530293, is a BF Goodrich tire, with all the usual tire info, ratings, approvals, warranties and has the 3/8" dual red stripes factory installed. At the moment it seems if I want a dual red stripe tire and a radial performance tire this might be it ? Kinda exploring the subject at the moment and learning. Thanks, Brian
jwc66k:
--- Quote from: Brian Conway on December 16, 2017, 04:56:55 PM ---It is my understanding that a concourse correct dual redline tire is not available in the after market ? Things change and I could be wrong ?
--- End quote ---
Did you read reply number 1?
--- Quote from: Brian Conway on December 16, 2017, 04:56:55 PM ---Rockhouse and Lancelot66's using/suggesting Diamond Back is certainly an option.
--- End quote ---
No.
--- Quote from: Brian Conway on December 16, 2017, 04:56:55 PM ---That tire is from Coker # 530293, is a BF Goodrich tire, with all the usual tire info, ratings, approvals, warranties and has the 3/8" dual red stripes factory installed.
--- End quote ---
This tire was not a factory option.
--- Quote from: Brian Conway on December 16, 2017, 04:56:55 PM ---At the moment it seems if I want a dual red stripe tire and a radial performance tire this might be it ?
--- End quote ---
--- Quote from: jwc66k on December 15, 2017, 04:30:35 PM ---https://www.cokertire.com/tires/styles/redline-tires/u-s-royal-redline.html
--- End quote ---
Correct supplier, correct dual redline, cheaper at $171.
[#] Next page
[*] Previous page
