Author Topic: 70 Dearborn pictures - Early Feb 70 build Mach I  (Read 3871 times)
« on: September 06, 2009, 06:08:34 PM »
Thought I would post some pictures of fairly original cars to help others. We accept that every car will have some items that have been changed either due to maintenance or owners modifications. As always do your homework.
Car is an early Feb Dearborn Mach I (0F05R163xxx) with P/S & automatic
Hope these help.
Bottom of hood surface
Grill area. Notice short hood/radiator seal and retaining clips. Batch color on the shock tower supports and hood latch supports are noticeable in the photo.
Passenger side of engine forward
Overall engine shot from drivers side
Drivers side interior shot
Console - radio area
Taillight panel and rear valance
Trunk lid with prop rod and mount
Original trunk mat and full size underlayment. Also shows that the worker applying sound deadener in the quarter panels may have made an effort to stay away from the side marker hole. Notice the passenger side wheelwell luggauge protector strip - gray this time
Front passenger side frame rail showing body color and sound deadener. Also idler arm (PS mark) paint identification stripe
Drivers side front frame rail showing (from outside to in) pinch weld black-out, Mach I sound deadener and body color overspray on frame rail.
« Last Edit: January 04, 2018, 04:19:00 PM by J_Speegle »
Offline rockhouse66
Re: 70 Dearborn pictures - Early Feb 70 build Mach I
« Reply #1 on: September 06, 2009, 09:19:43 PM »
Jeff - I am interested in the idler arm attaching bolts.  The '69 Assembly Manual says 428 cars should have them installed with the nuts on the outside due to "decking" clearance issues.  I don't recall seeing any like that, but this car has one of each!  Comment?
'66 GT FB, '69 CJ Grande
« Reply #2 on: September 07, 2009, 01:43:16 AM »
Yes noticed the same in the pictures but they may be original (not the first time the assembly manuals were different than the production practices)
I'll find time and look through some other cars to see if I can find some more the same.
"Decking"  that's an interesting term .... hmm BTW is that from the 69 or 70 assembly manual?
Offline rockhouse66
« Reply #3 on: September 07, 2009, 08:38:32 AM »
Jeff - it is in the '69 Assembly Manual.  Could be in the '70 manual too but I don't have one to check.  I can see where the ends of the idler arm bolts could stick out far enough to foul the PS exhaust manifold on the way in, so it makes sense.
I always drop the idler to install the engine, but obviously they would not do that on the assembly line.
Offline mmv.mustangs
« Reply #4 on: September 08, 2009, 06:30:27 PM »
Jeff, great pictures. However, I've noticed the attaching hardware on the hood hinges have small washers. This appears to be a questionable item. I've looked at many original cars and from different plants, and there is no rhyme or reason as to why some have standard washer bolts, and others have the larger washers. I'm a firm believer that there should never be a point deduction because ones car does not have the larger washers. Also please note Mustang Monthly, July 2009 issue, "Resto Roundup" Perkins has addressed this particular issue concerning bolts and the many variety. Great topic for the upcoming judges meeting.
Mark Vasquez
« Reply #5 on: September 13, 2009, 12:39:50 AM »
Jeff, great pictures. However, I've noticed the attaching hardware on the hood hinges have small washers. This appears to be a questionable item. I've looked at many original cars and from different plants, and there is no rhyme or reason as to why some have standard washer bolts, and others have the larger washers.....
Looking through the pictures I have I found that this may be a difference between 69 and 70/ And we know how many of us can blur details across years.
Just starting with the 70 Dearborn cars (since that is what was posted in the pictures above) I found very few of the ones I have had the large washers used with the hood bolts as you mention. I stopped counting (guess I could also go back and make a list of the VINs)
« Last Edit: January 04, 2018, 04:32:55 PM by J_Speegle »
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
« Reply #6 on: January 04, 2018, 02:01:01 PM »
Well that's strange, now the pics are not there.  I did see them.
MCA#31064
« Reply #7 on: January 04, 2018, 04:05:58 PM »
Me too. Last night there today - dead. Just more of the love PhotoBucket offers
Working on the cure
« Reply #8 on: January 04, 2018, 04:26:26 PM »
Some additional pictures while I'm here
EXTERIOR
EXT1
Rear pinchweld black out - Drivers side rear quarter panel
EXT2Exhaust tip and back up light
EXT3 Taillight panel overlay and rear lettering
EXT4Side molding at front edge of rear wheelwell showing black out between the molding panels
EXT5 Side molding with door black out
EXT6 Front turn indicators up close
EXT7 And the back side and support brackets
EXT8
EXT9
« Last Edit: January 04, 2018, 04:31:35 PM by J_Speegle »
« Reply #9 on: January 04, 2018, 04:30:51 PM »
UNDERCARRIAGE
U1 Wheel side of front fender splash shield (forward one) on drivers side
U2 Power steering and pittman arm
U3 Front strut bracket. Shows (this is a 1970 Dearborn) where the firewall area was shot in a batch paint/sealer. Also shows from paint markings for a 70 Mach I
Offline JohnRB
« Reply #10 on: January 04, 2018, 06:12:23 PM »
Perfect
