Restoring - General discussions that span across many different groups of years and models => Suspension => Topic started by: austr6 on September 30, 2016, 08:46:48 PM
Title: Tie rod adjuster sleeves
Post by: austr6 on September 30, 2016, 08:46:48 PM
Hello all,
I have a question regarding the tie rod adjuster sleeves (the threaded piece of pipe with clamps at either end between the inner and outer tie rods).
my vehicle has the factory fitted power steering, and it has the same diameter sleeves on the l/h side as well as the r/h side.
Is this correct for my vehicle or should one size be a much larger diameter than the other? according to my supplier of parts, he believes it should be the later of the two ? but he is not 100% sure.
Kind regards, Richard.
Title: Re: Tie rod adjuster sleeves
Post by: jwc66k on October 01, 2016, 12:33:28 AM
He's correct, the left side is larger and uses different clamps and bolts, 379179-S2. That bolt has a square "shoulder" at the head (it's still a hex head bolt) and it's a 3/8-24X1 5/8 inch long, grade 5. The nut is special too, 372755-S(8) 3/8-24 cone locking.
All the above hardware is documented in the Library section of this forum under "Mustang Hardware Spreadsheet 64-66". You will find two spreadsheet, one by part number, the other by application, aka location/application. Under the application scan down to "Tie Rod - - " for further info. The source is the 75 Ford Car parts, MPC, SEC 030 P18,ILL 036 P04, 05, 06. As far as I can tell, the bolt is not reproduced and is only available from salvage yards.
