Author Topic: Now for something different. #1 Part II  (Read 13014 times)
Re: Now for something different. #1 Part II
« Reply #60 on: April 09, 2017, 11:32:43 PM »
Passenger side drain hose cover used on 64 and 65 mustangs
+1   Example below
« Reply #61 on: April 09, 2017, 11:35:28 PM »
Next item SOme of these may seem pretty easy if you know the cars in that time period. But they are are all possible clues
Item #1- Identification - Passenger side rocker panel for coupe or fastback body
Application(s) - 64 1/2- through approx Dec 65/Jan 66 or 1967-69
Item #2- Identification - Passenger side seat riser/pedestals panel for coupe or fastback body
Application(s) - July 64 - Aug 68
Item #3- Identification - Blue/red wire were used for lamps controlled by the dash lamp circuitry or used for shifter lamps, controlled by whether the running lights were activated. Majority believe it is related to the shift lever light.
Application(s) - 64- 71?
Item #4- Identification - Under dash AC unit  air intake grill
Application(s) - 1964-65
Item #5- Identification - Duct tape
Application(s) - Anything you can slap it on  ::)
Item #6- Identification - Passenger side drain hose cover
Application(s) - 64 1/2 and 65 mustangs.
ITEM #7
Item #7 - Identification - _____________________  (Identification - What is it?)
Application(s) - _______________________________ (Application - What year/years and models was it used on?)
And while we're at this - How many can you see?
Online ruppstang
« Reply #62 on: April 10, 2017, 12:56:56 AM »
They are seat bolt access cover grommets, I see 6.
I think they were used 64 1/2 to at least 69.
Convertibles use six of these and two metal covers.
Online CharlesTurner
« Reply #63 on: April 10, 2017, 01:32:23 AM »
65-66 convertibles use 8 just like coupes/fastbacks.
Offline tobkob
« Reply #64 on: April 10, 2017, 10:29:34 AM »
I see 7 grommets.
« Reply #65 on: April 10, 2017, 07:21:52 PM »
Good - we have 7 visible seat bolt access covers/plugs
« Reply #66 on: April 10, 2017, 07:29:24 PM »
Next item some of these may seem pretty easy if you know the cars in that time period. But they are are all possible clues
Item #7- Identification - Seven front seat nut access covers/plugs
Application(s) - 64 1/2 and 66 mustangs all body types.
ITEM #8
Item #8 - Identification - _____________________  (Identification - What is it?)
There is a second group of the same type of items to the right. How many total do you see or believe there are in these two groups?
Now with #7 and #8 what does it tell us about the possible body style of the car in question? This would go along with the "Application" part above
« Reply #67 on: April 10, 2017, 07:48:35 PM »
Those look like seat rail to carpet protectors/brackets.
Online ruppstang
« Reply #68 on: April 10, 2017, 09:26:16 PM »
I agree they are seat carpet track protectors. They were use through 1967. They were built on the 68 tracks.
I think there are only 6 plugs the 7th one looks smaller.
« Reply #69 on: April 10, 2017, 11:19:05 PM »
Offline tim_morrison82
    • Click Here for My Project
« Reply #70 on: April 12, 2017, 04:08:31 AM »
i can see 4, but not sure if there is more under the pile with the number as there seems to be another piece of steel angled differently under the 2 you can see. if there is only 4 total, its a bench, other wise its bucket seats.
« Reply #71 on: April 12, 2017, 05:06:10 AM »
I think I can make out at least 5 or more, depends on how high they are stacked int he pile to the right.
If it was a bench seat car what would it tell us about the possible body style given the other clues so far?
« Reply #72 on: April 12, 2017, 06:37:33 AM »
If it was a bench seat, then it could only be a coupe or convertible.
« Reply #73 on: April 12, 2017, 10:04:00 AM »
if thats true, we rule out fastback, and we also rule out convertible - so bench seat = coupe in this instance.
however, 5 carpet track protectors? is it possible to use them as shims to level the seat out?
« Reply #74 on: April 12, 2017, 04:33:05 PM »
In 65-67 your correct and that is where the clues seem to be heading. Just wanted to get that discussion covered to maximize the information we can glean from just a picture.
Since there are more than 4 plates/spacers and more than 4 seat nut access plugs that were removed we can guess it likely had front bucket seats and back again to either coupe or fastback again.
