Author Topic: Drive Shaft markings  (Read 384 times)
Offline Herman
« on: June 15, 2017, 08:41:51 PM »
I recently picked up an original drive shaft from a 66 automatic car and would like to get some information on the markings.
Washing, polishing and cleaning stuff some more in an attempt to retain that 'Golden nugget'
Offline Herman
Re: Drive Shaft markings
« Reply #1 on: June 15, 2017, 08:43:27 PM »
Unfortunately these are the best photos l have
Offline rrenz
« Reply #2 on: June 15, 2017, 10:01:20 PM »
Cant really report on what the markings actually mean after doing many hours of research during the restoration of mine. I also have a 66 automatic with markings that were same in color however completely different in location from this. I suppose every worker had their own "thing". One thing that is cool are the numbers which were stamped on the steel tubing. I believe they got 3 drive shafts from one piece of stock so only one of three pieces had the numbers present. Perhaps someone else may have some more insight.
Ryan
C-4 Automatic
Build Date Jan 21st
Offline Herman
« Reply #3 on: June 15, 2017, 10:22:36 PM »
Thanks for the response.  I was able to get a better photo of the yellow part number on the drive shaft.
Offline ChrisV289
« Reply #4 on: June 17, 2017, 12:16:39 PM »
What is the approximate height of the numbers?
1965 Honey Gold Fastback
« Reply #5 on: June 17, 2017, 04:51:06 PM »
That's the supplier's stock number, not a Ford part number, and not all drive shafts came with the supplier's stock number. The drive shafts were cut to length from a 20 foot long tube to make a raw shaft so if yours doesn't have the supplier markings, don't add them. (On the other hand, if the numbers look nasty, remove them - Goof-Off works.)
Offline ChrisV289
« Reply #6 on: June 17, 2017, 05:31:00 PM »
Mine did but I can't find the picture of the measurements I took of the height just location. And want to order the right stencil kit. I think I posted in another thread that mine was 11W at the end
« Reply #7 on: June 17, 2017, 06:14:22 PM »
Chris,
Those marking are NOT required.
« Reply #8 on: June 18, 2017, 11:56:49 PM »
Especially since they were not on all drivelines. As we understand from a Ford worker from San Jose one out of three would have had the tube ID stencil
Offline Herman
« Reply #9 on: June 20, 2017, 01:38:51 AM »
Thanks everyone for the responses.  Funny thing is both my of cars had the stencils and now this one.
