Author Topic: 1966 Mustang San Jose t-code Convertible  (Read 1465 times)
Offline dsielke
Re: 1966 Mustang San Jose t-code Convertible
« Reply #15 on: October 16, 2017, 07:42:37 PM »
Quote
Also believe the C4AF-11001- isn't the correct engineering number for a 66 6 cylinder with automatic starter.
What would the correct engineering number be? Looks like I may need to have a new stamp made. :)
6R09A138419: 1966 GT Fastback, Springtime Yellow
6R08T138429: 1966 Convertible, Tahoe Turquoise
« Reply #16 on: October 16, 2017, 07:47:57 PM »
Looking at the original car in the link in the earlier post and others it appears C3AF-11001-A would be correct
PM sent  ;)
Offline dsielke
« Reply #17 on: November 17, 2017, 12:45:11 PM »
I finally get a day off after working 12 hours a day 7 days a week for 2 months straight...yes I am serious. So what do I decide to do with my day. Fix issues Jeff pointed out on my Convertible. He is such a trouble maker.  ;)
I am sure other could have feathered the leading edge better but I am happy with it. I also stripped the feather edge of the starter a bit and restamped it.
Offline dsielke
« Reply #18 on: November 21, 2017, 02:18:35 AM »
My engine tag finally showed up.  8)
Offline dsielke
« Reply #19 on: November 22, 2017, 03:41:54 PM »
I just started cleaning the dealer undercoating off the car. I know it won’t be as “fresh” as a full undercarriage restoration but it will be original. I will be replacing any suspension parts that aren’t correct or are worn and cleaning up those that are. I have not painted anything, just cleaned with scrapers and mineral spirits, that little bit of black overspray I would assume is when they originally painted the engine compartment at the factory.
This is why I love California classic cars.  8)
« Last Edit: November 25, 2017, 07:28:49 PM by dsielke »
« Reply #20 on: November 22, 2017, 04:14:48 PM »
Spent many hours on my back doing just that on a February build, San Jose, 66 GT Fastback about 20 years ago. It was my learning experience. The second one was supposed to be easier. Ug.
Offline dsielke
« Reply #21 on: November 25, 2017, 07:30:31 PM »
A little more done today. This is going to take awhile...
Nothing but carefully scraping the top layer of undercoating and lots of rags and mineral spirits. Very messy. The factory was messy with blacking out. Lots of runs.
« Last Edit: November 25, 2017, 07:33:51 PM by dsielke »
« Reply #22 on: November 27, 2017, 02:50:35 PM »
Looks nice - your getting there
Offline dsielke
« Reply #23 on: December 02, 2017, 04:57:57 PM »
A little more done today. It’s like a time capsule. Before and after is telling.  :)
The scrapes near the hold down area were under the undercoating. Probably on the assembly line or in shipping.
Offline dsielke
« Reply #24 on: December 17, 2017, 12:31:35 AM »
First pass on passenger floor pan cleaning done
« Reply #25 on: December 17, 2017, 02:16:25 PM »
Very nice job!!
Offline dsielke
« Reply #26 on: December 17, 2017, 11:54:55 PM »
I got a couple of hours in this weekend to start on the drivers side.  :)
By the way, had to switch to turpentine since mineral spirits isn’t available in SoCal any longer, I had a mask and fans going but the smell of pine kept my family out of the garage. :(
« Last Edit: December 17, 2017, 11:58:50 PM by dsielke »
Offline dsielke
« Reply #27 on: December 28, 2017, 02:12:06 PM »
Got a little more work done. Stripped and repainted the lower outer rockers and black out. I feathered into the floor pan black out to take care of some of the worst scrapes from cleaning. I also removed and cleaned the reinforcement plate, no painting.
Offline dsielke
« Reply #28 on: December 31, 2017, 09:32:37 PM »
Today I brushed on the sealant that was recommended to the rocker edges and touched up the blackout feathering into it. It probably would have come out smoother if I would have removed more of the original, you can see it in spots making it more clumped than I might like. The differential is going to get a cleaning pass next.
« Reply #29 on: December 31, 2017, 10:21:02 PM »
............I also removed and cleaned the reinforcement plate, no painting.
Sure looks like that plate may be batch (dark grey) rather than black. Can you confirm the color by checking it against something painted black so others building 66 NJ SJ cars will have an idea?
Guess your not done (last picture) with all the cleaning since the drain plug/plate still appears dirty or blackish.
Wonderful car hiding under the years and "stuff"
« Last Edit: January 01, 2018, 01:23:45 AM by J_Speegle »
