Author Topic: 67 San Jose Shelby  (Read 548 times)
  • 20 minutes from Pacific Raceways
67 San Jose Shelby
« on: October 19, 2017, 10:07:15 PM »
You've been putting up with me for a number of weeks now, so I thought I'd show you the reason for my latest flurry of posts ... an early March SJ Shelby GT350.
The restoration was started almost 20 years ago, but major house projects, other car projects, plus SCCA style racing keep this car on the back burner. Actually off the stove.
Here is the original car, more than 20 years ago:
And here it is today:
A shot of the complete metal work on the floor by hammer welding the floor replacement panels:
Major body work is done, you've followed along on the matching number fenders and the replacement rear deck. The rest of the car is mostly stock metal, save for some partial floor replacements. The doors are original as is the rest of the fiberglass.
The non-stock traction bar stuff is gone, so a little red oxide repaint and on to the concours prep for paint (sealer and other fun stuff).
« Last Edit: December 06, 2017, 01:36:32 PM by Bossbill »
Concours 3/2/67 GT350
Driven     6/6/70 0T02G160xxx B302
Modified  5/18/65 5F09A728xxx 2+2
Race       65 Coupe front clip, Convertible frame mods and SFCs; 2+2 conversion; Many 'glass parts
Re: 67 San Jose Shelby
« Reply #1 on: October 19, 2017, 11:02:59 PM »
Thanks for sharing
Offline rodster
« Reply #2 on: October 19, 2017, 11:20:13 PM »
Looks great!   Life has a way of happening and sometime toys have to wait. Glad it's moved to the front burner!!  :)
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #3 on: October 20, 2017, 09:43:56 AM »
looking good but don't forget to replicate the dolly marks.
« Reply #4 on: October 20, 2017, 12:25:11 PM »
look again :)
« Reply #5 on: October 20, 2017, 12:28:14 PM »
I have a lot of pics and chose this one more for it's lighting than anything else.
 I'm working on the correct dolly hold down marks in the trunk.
On edit ... I use balloons in holes to keep paint from going through to the interior.
The comments on dolly marks made me look and I see I have large washers in use as the faux dolly. This was years before I saw the library thread on how to really do them right.
Still thinking about this.
« Last Edit: October 20, 2017, 12:37:59 PM by Bossbill »
« Reply #6 on: November 10, 2017, 01:23:47 PM »
An update since I posted the pictures above. Some of this is a recap from some other posting in this forum, but included here as a summary.
* Procured a correct (but lightly damaged) fiberglass trunk lid. Also found some uncut NOS keys.
* Repaired and used red oxide (RO) on the original front fenders after having them dipped, acid etched and rust converted. The repair involved a bottom corner which mandated a reassembly of the hinges and door in order to verify lineups. There is no bleed from the dipping process.
* Sanded down the entire interior of the car in preparation for RO and then the overspray of light primer and body color. Procured a seam sealer pressure gun, but the cap was missing so seam sealing is on hold.
* Thanks to "Midlife" I have a much nicer fuse box and he is also sending me some front harness headlight connectors to repair the SA 3M Scotchlok issues (these damned things eat wires alive). Started cleaning up wire looms and will re-wrap them using my newly found harness vinyl. Cleaning each and every wire poking out of all the looms. I now have 496 spare Scotchloks.
* Used a scotch pad and gave some tooth to the entire backside of the dash and under cowl. That was fun. Painted the entire back of the dash with metal look Rustoleum. That was as much fun as scotch pad! This area will get RO near the floors and have the correct dash color overspray when the dash gets painted. Waiting on that paint from the painter.
Also used the metal look in areas of the trunk that don't always get paint to replicate bare metal.
* Doors have been stripped of all interior color. Waiting on dash paint here too.
* Removed the traction bar setup and ROed the repair. Found another area with a pin prick hole and replaced with metal, then RO.
* While I had a RO mix, I removed the paint from the trunk interior at the trolley site, cleared the metal, placed appropriate sized washers on the area and bolted the whole affair down (including under the car) for final seam sealers and color sprays.
Here is a pic the back of the dash because we all like pictures . The gloss is mostly from the flash.
and finally this afternoon, I taped off and then sprayed the interior (except for the dash and firewall) with RO.
« Last Edit: November 10, 2017, 06:49:54 PM by Bossbill »
« Reply #7 on: December 31, 2017, 10:20:02 PM »
My painter has an opening now, so I have delivered him my front fenders for initial bodywork.
The fenders are in really good shape (see thread about dipping) and the bodywork is to get them ready for the next stage -- skimming and block out.
With the fenders goes a few ConcoursMustang.com pics of how much overspray of primer and body color is allowed.
I will do this with all parts or tell him to cover those areas for my prep.
Next will come the doors, scoops and 'glass nose for initial body work.
The car will be delivered with the glass hood and trunk lid later. But first I have to create some drips and finish the seam sealer stuff. More products are needed so they were just ordered. pics will be posted later! Jeff will be amazed that I ordered Spectrum Sludge -- mostly to keep down on the amount of spray seam sealer required.
I've really been busy with process development. Thanks to this site I've been working out the exact processes for phosphate and oil as well as the zinc and oil. Zinc electro plating is next. Wiring repair is another area of expertise that had to be developed. Working on the process to recover the door light wiring harness with new tubular wire sheath. I'll make a post about how I did that when the sheath arrives.
I also need more of this sheath for the headlights (center Shelby) in order for them to be pliable and for the underdash gauges. I also used this site's library as a guide for the back-up light wiring move to new housings.
Meanwhile some smaller items have been glass media blasted and painted with different semi-gloss blacks to get that different vendor look.
If you've followed any of my posts you'll notice I bounce around a lot, but as I run out of parts or ability to process some parts, I move to others in order to keep moving.
« Reply #8 on: January 03, 2018, 10:15:31 PM »
I just bought a parts car in order to source some extremely hard to find parts.
The car has a "7R01C189xxx" vin only a few thousand numbers from my SJ car and it still has its SJ specific firewall pad and soft dash pad!
If you have ever tried to find these parts, you'll know what I mean.
Plus I get to see the seams and sound deadener up close and personal -- and well within the range of my car.
Just today I found the small oblong plug  on the voltage regulator side of the core support! Nothing on the battery side. But, this car cannot be considered unmolested.
After I take what I need I may offer this up here for the various small parts so hard to find outside of a parts car.
Now I have to figure out how to open the doors, as the mechanism on both sides seems to be jammed or rusted.
« Reply #9 on: January 03, 2018, 11:06:40 PM »
Nice find. Never understood why the 60's restorers generally don't buy parts cars especially as wrecking yards dried up for many parts of this country.  The practice is/was almost automatic for restorers of the 20-50's cars as I grew up its been hard to understand the resistance.  Plus all the extra hardware and little pieces that if purchased separately from different sources can never replicate a single period of time and instead create a more watered down version with a detail from this period and another from a different one.  With just the couple of good hard to find pieces I think you did well
« Reply #10 on: January 03, 2018, 11:39:12 PM »
The plug on the regulator side is typical. The passenger side is typical to not have one. I suppose it was to protect water from getting on the regulator. The other side didn't have a water sensitive item to protect. At least that is what I have always believed.
« Reply #11 on: January 04, 2018, 12:51:52 AM »
Jeff -- It was pure luck it was a SJ car -- pure coincidence that it was close to my VIN.
Bob -- Yes, I remembered that detail from a thread in this forum. I was actually excited to see a two-bit plug in this car.
You guys have ruined me!
