1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: ChrisV289 on March 18, 2017, 03:36:34 PM
Title: Castle nut?
Post by: ChrisV289 on March 18, 2017, 03:36:34 PM
I forget, which castle nut goes to the bottom and top control arm where it holds the spindle. I forgot to mark them when I took them off
Title: Re: Castle nut?
Post by: jwc66k on March 18, 2017, 04:17:34 PM
Did you look in the library? Under topic "Mustang Hardware Spreadsheet,64-66" in the by application section, you will find your answer. (Hint, it's "Ball Joint" related.)
To further confuse the issue, or add clarity - try the topic "Hardware By Size/Dimension -". You need to know what the size of the nut you are looking for?
Post by: ChrisV289 on March 18, 2017, 04:18:51 PM
I'm in the garage working on the car on my iPhone. Thought this would be faster than trying to look at the spreadsheet. Can you just please give me the answer so I don't have to waste time going back in the house
Post by: CharlesTurner on March 18, 2017, 05:07:26 PM
The tall one is for the upper/lower ball joints.  Shorter is usually for the idler arm.
Post by: ChrisV289 on March 18, 2017, 05:15:36 PM
Interesting because I have two of each and all four came off the ball joints when I took it apart a few months ago. I haven't messed with the idler arm at all.
Post by: Bob Gaines on March 18, 2017, 07:03:03 PM
Some of the after market ball joints require a shorter castle nut for the cotter pin to line up properly . The shorter nut on a stock ball joint will have the cotter pin opening far enough above the castle turrets that it defeats the purpose of the castle nut. I don't know if  this is your reason but this a common circumstance that I have seen.
