Restoring - General discussions that span across many different groups of years and models => Drivetrain => Topic started by: preaction on June 29, 2017, 07:18:49 PM
Title: C6 trans Vin number
Post by: preaction on June 29, 2017, 07:18:49 PM
Is this typical of a mustang C6 transmission vin stamping,   9R*131845   also this trans has a G servo. This C6 was in my 68 mustang when I purchased it in San Francisco. Seems to be from a 69 and not my car.
Title: Re: C6 trans Vin number
Post by: Coralsnake on June 29, 2017, 07:45:00 PM
Typically 1968 and later transmission have derivative serial numbers
Post by: RoyceP on June 30, 2017, 04:19:09 AM
If it was the original from your car it would match your car's serial number except the body code and engine codes are omitted. Same as the VIN stamp on the engine.
Post by: Bob Gaines on June 30, 2017, 11:35:01 AM
 I am not sure if this explanation is right for your car but it is for many. It was typical for transmission shops back in the day to treat a transmission case as just a generic core .Cores were not kept track of and if a different one was already cleaned up or even completely rebuilt a switch was made. It was not seen or meant as underhanded just the way it was done when the cars were all drivers. Now days a C6 core is less common and even "if " you didn't ask to have your own core rebuilt they probably would because other cores are less likely to be on hand.This core switcheroo is one of the more common explanations for why a original transmission case is not with a given car.
Post by: jwc66k on June 30, 2017, 01:03:16 PM
I am not sure if this explanation is right for your car but it is for many. It was typical for transmission shops back in the day to treat a transmission case as just a generic core. -
Exactly. When faced with the time factor, 2 or 3 days (at least) to rebuild, or same day replacement, the same day option often won.
Post by: preaction on June 30, 2017, 04:31:45 PM
Thanks for the replies don't get me wrong I'm not sad my car may not have its original transmission I purchased it as a used car and that comes with the territory I'm more curious about the stamping and if this is what a Vin on a 69 car would look like. Since the trans shop theory is a good one I believe could this be a trans from another car model ? For me the asterisk was a surprise.
Post by: J_Speegle on June 30, 2017, 06:23:31 PM
Practice depends on plant and year in some cases there is only the sequential number on 68- up transmissions
preaction guess you found something like this example but have not seen one with an asterisk
(http://www.concoursmustang.com/forum/gallery/7/6-300617172147.jpeg)
