1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1971 - 1973 => Topic started by: Ashley on August 23, 2017, 12:40:07 AM
Anyone own a 71 Mach 1 or sportsroof with 429 CJ and C6 trans? Leaf springs on my car has a C9ZA-5556-G stamping number on short leaf. Megasite shows a spring with D1ZA-5556-SA stamping from a 429 car. Purchased new OE springs from Eaton. Looking for the short leafs with correct stamping number. Any info would be appreciated.
Not sure. Are you looking for confirmation on the D1ZA-5556-SA spring engineering number or looking for a pair?
If looking for I suggest that you place a ad in the wanted section and other sites. The more the better and the more eyes you will reach. Also figure out if they were used on other models of 71-73s to help widen the search and possible match.
If looking for confirmation hope other owners can check their springs and report. Only own a Cougar 71 CJ (don't own 71 Mustangs any longer) think those may be different
Springs on my 72 H Code 351C, Mach 1. Just for additional information, try and save the original spring clamps. No one reproduces the original round hole with bell shaped stamp.
Yes looking for confirmation of number on spring and to purchase short leafs with correct number. Interesting nhams car with 351 engine has the same suffix SA as 429 CJ. Thinking the suffix letters determined rating of spring. Looked at an original spring on a Boss 351 with a D1ZA-5556-AB number. Anyone know of a source for leafs please reply. Thanks Jeff and nham
.......... No one reproduces the original round hole with bell shaped stamp.
Believe at least one shop reproduces the round hole clamps but not often or enough to keep a supply all the time sort of done when he needs some then sells out fairly quickly
Thanks for the picture since I thought the application was wider than just the one application that year. Will make finding some a bit easier for the OP
