Author Topic: Heat shields over motor mounts or not?  (Read 3036 times)
Offline fast66
« on: February 12, 2015, 10:02:11 AM »
Hi,
On my -64 April 260 I know that there should be steel heat shields between the block and motor mounts.
I also have a late November -66 with 289/C4. Should the heat shields (none there today) be present in this setup also regardless of type of motor mount?
thanks,
Claes
« Last Edit: October 13, 2017, 09:44:37 PM by carlite65 »
6T09K212784
63A 4 25 21B 951384 5 6
Offline Richard P.
Re: Heat shields ove motor mounts or not?
« Reply #1 on: February 12, 2015, 04:20:21 PM »
I've seen the heat shields on late 1966 V8 Mustangs.
« Reply #2 on: February 12, 2015, 08:22:51 PM »
Will see if the pictures turn up. As a somewhat related note - some of the other later small blocks used a single heat shield on the passenger side motor mount only
Online outlawincorporated
  • Kangaroo Herder
« Reply #3 on: February 12, 2015, 10:55:40 PM »
I just recently started a resto on a unrestored 66 NJ (april) convertible and there is/was only one heat shield on the passenger side.  got me thinking!!!!!
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Offline rocket289k
« Reply #4 on: February 13, 2015, 12:56:06 AM »
During the restoration of my late July 1965 projected build date Metuchen car I found heat shields on both the driver and the passenger side motor mounts.
Regards,
Ron
« Reply #5 on: February 13, 2015, 11:19:52 AM »
I have mostly seen a single one used on passenger side (LHD), but have also seen cars with it used on both.  If I was judging a car, I would accept either config.
Does the assembly manual have anything on this?
Offline Richard P.
« Reply #6 on: February 13, 2015, 04:57:14 PM »
I've also seen the heat shields on one or both sides. If only on one side it will be the left as that is the torque side and will weaken before the right side.
« Reply #7 on: February 13, 2015, 05:05:57 PM »
Passenger side (where we're finding the single installations and where Ford installed them on the Boss for example) would be the compression side - the reason the old racers would fab a limiting rod or cable on the drivers side since that is the side that would normally go first.
Maybe the same idea but we're using different terms :)
Offline 66RavenGTCoupeAgain
« Reply #8 on: October 13, 2017, 05:30:33 AM »
Were these shields natural or block color?
My unrestored engine had no shields at all Dec 65 build.
66 Metuchen NJ  GT Coupe
Raven with Deluxe Black Int 289 A Code C4 PS Tinted Windows (Green) Dealer installed Rear Speaker
6T07A1612## Dec 65 Build
65 San Jose CA Convertible Rangoon Red with White Int and Power Top with plastic rear window 289 C Code C4 PS PB AC Fog Lights
5R08C1496## Oct 64 Build
« Reply #9 on: October 13, 2017, 10:54:05 AM »
Natural steel
  • Kangaroo Herder
« Reply #10 on: October 13, 2017, 09:43:45 PM »
+1 to natural steel.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA
Offline mgmradio
Re: Heat shields over motor mounts or not?
« Reply #11 on: October 14, 2017, 09:55:28 PM »
My August 64 289 4v and both my June 65 289's have heat shields on both sides.
Formerly the MCA ANHJ 64.5-66!
« Reply #12 on: October 15, 2017, 09:47:33 PM »
Thanks PB and Caspian.
Online jwc66k
« Reply #13 on: October 16, 2017, 12:32:09 AM »
It says 2 required, 6C038 in the 64 Assembly manual and in the MPC sect 60.4 pg 5 as C3DZ-6C038-A thru 1968 for 260/289 (ex HP).
This is one of those often left off or forgotten parts. On a 66 GT Fastback I had, there was only one, so I had the machine shop make a couple dozen for me. They used electro-galvanized steel, what was on hand and not allocated to a contract.
