Author Topic: Carburetor Parts Sources -  (Read 2407 times)
« on: September 02, 2017, 02:08:26 PM »
I bought a pair of 2100/4100 idle adjusting screws recently. They were made from brass. The originals are made from steel. I assume the brass will "function" as originals, but are not correct. The steel screws can be plated but the needle points in the idle circuit will not function properly. Is there a recommended source for steel idle adjusting screws?
Offline lancelot66
Re: Carburetor Parts Sources -
« Reply #1 on: September 03, 2017, 09:45:29 PM »
Jim,
I thought I could find just about anything but steel Autolite 2100 or 4100 idle adjusting screws are more difficult to find than I gave credit for.
If a person goes to a  donor carb for a source, you could very well be back in the same situation of why you needed them in the first place.
Every thing I've found so far has been brass, as I'm sure you found out already.
Not helpful but I'll keep looking.
« Last Edit: September 04, 2017, 02:52:46 PM by lancelot66 »
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
Offline Deuce
« Reply #2 on: September 04, 2017, 03:28:18 PM »
Another carburetor parts topic, so posting here instead of in 1967-1968 section.  (please move if more appropriate there).
Acquired a correct C7DF-V Autolite 2100 carburetor for '67 coupe with T/E.  For the carb rebuild, looking for the rubber bowl vent valve that attaches to the vent linkage.
The b/w photo is copied from Mannell book (isn't very good resolution); second photo shows C7DF-V carb without the bowl vent valve attached to the linkage.
Can the vent valve be sourced from somewhere?  As far as I know, 2100 rebuild kits do not include this rubber vent valve.
Deuce
2008 Premium GT Coupe, 5-speed, rear spoiler delete, HID headlamps, well-optioned, Flat Rock built Oct 23 2007, RC 72
« Reply #3 on: September 04, 2017, 04:27:59 PM »
I happen to have my MPC open the carburetor section so I looked. The carb in question, C7DF-V, uses parts list Sect95.11V. The top cover of the carburetor use a different part number, C7AX-9524-A, which is only common to another carburetor documented in section 95.11R. A quick cross reference show a full size Ford, 289 2V AT with smog application. In other words, not many applications to chose from. That's the why, I don't known the where or how to get a replacement plug.
« Reply #4 on: September 04, 2017, 04:36:09 PM »
Lance,
Thanks. I assumed a steel part when I ordered, but I'm not surprised. You're right about replating, so a light touchup with steel wool seems to be the solution at this time. It looks like 4100 and 2100 (to what year TBD) carbs used this particular adjusting screw.
Offline Deuce
« Reply #5 on: September 04, 2017, 05:02:03 PM »
Jim, RE: vent valve plug,
Thanks for the MPC info.  C7DF-V carb applications from Mannel (p. C-5) show these 1967 289 2V T/E vehicles with automatic transmission:  full size Ford, Fairlane/Torino, Comet/Cyclone, Mustang, Cougar and Falcon.
I saw the NPD listing for idle adjustment needle screws; I wouldn't have guessed they are brass from the photo (and no description of material): https://www.npdlink.com/store/products/mustang_needle_screws_idle_adjustment_pair-196090-409.html
Deuce
« Reply #6 on: September 04, 2017, 07:01:45 PM »
Plug looks very similar to the one typically used on 67 up Holley bowls.i held a holley bowl in my hand and compared to picture. It looks close. It may be worth looking into. The Holley rubber plugs are very common .
« Reply #7 on: September 05, 2017, 12:14:15 AM »
Those work, but they are the wrong style. The style for 2100 and 4100 is attached. I'll figure out years tomorrow.
Offline Deuce
« Reply #8 on: September 05, 2017, 09:07:46 AM »
Haven't dealt with Holleys much, at least in the recent past.  Is there a known or common Holley parts source I can consult?
Here's a better picture of the 2100 vent assembly, this photo is from an online article about a 1969 Mustang application:
Deuce
Offline lancelot66
« Reply #9 on: September 05, 2017, 09:42:30 AM »
Duece,
Try this guy out. I have bought from him before. He has the vent valves I think you're looking for:
http://www.ebay.com/itm/Rubber-Vent-Valve-Ford-Motorcraft-Autolite-2-bbl-Carburetor-pkf-of-2-/142471189501?hash=item212bf1d3fd:g:IOgAAOSws-1ZiziO
Now, back to Jim's steel idle screws.....!
Cheers gentlemen!
VR/
-Lance
SJ Build Date: 1/6
Offline Deuce
« Reply #10 on: September 05, 2017, 10:02:45 AM »
Duece,
Cheers gentlemen!
Thank you Lance!  I'll pursue this and provide feedback in case anyone else will be searching for these 2100-style vent valves.
Deuce
