Author Topic: 1968 unrestored High Country Special  (Read 914 times)
Re: 1968 unrestored High Country Special
« Reply #15 on: September 27, 2017, 03:01:25 PM »
Perhaps the elevation of Durango Co. (6,5012 above sea level) comes into play here. High elevation and/or combined with travel between high elevation to lower elevations, wreak havoc on an otherwise "good tune-up" and perhaps vehicles set up with "High Altitude Emissions" systems were exempt (at least given the combination of options of this particular example). Just a thought. This would not necessarily include EVERY HCS made with manual transmissions but perhaps certain DSO's only.
Never seen any reference to regional exceptions in the Federal law at the time. Nor see any notes in the testing material for the sates.  Think (based on what we know at the moment) thing this is a bit of a very big stretch
Did I miss something - where did the High Altitude Emission systems term come from?  I see it used in modern engines but don't find any reference 50 years ago  so wanted to ask  :)
« Reply #16 on: September 27, 2017, 05:08:00 PM »
Just a term I learned most likely in the 80's. I figure Ford was not unaware of how altitude affected carburetor  systems in the 1960's and essentially assumed they built things accordingly even 50 years ago, mostly since the advent of automatic chokes being used nearly 100% of applications by then. I agree it perhaps a stretch for the 60's cars but thought if it helped narrow down the examples that could have been built same as Marty's example is. (assuming again that everything is 100% stock as claimed and supported with date codes ;)
I'd like to hear what Kevin Marti might be able to find out. My guess is that there are others the same. (another assumption on my part ;) )
1967 (11/2/66, S.J.) Luxury Coupe, 289-4V w/Thermactor Emissions, C-4, Well Optioned
« Reply #17 on: September 27, 2017, 05:46:43 PM »
Agree that this is something we need to continue to watch for. Unfortunately not allot of manual trans cars in 68 with small blocks. Did look through my pictures and I don't have anything that could help from any of the three plants for late 68 production.
« Reply #18 on: September 28, 2017, 12:43:48 AM »
I looked through the Mannel book again at 1969 and there were no TE systems. Most likely it was indeed discontinued in late 68.
« Reply #19 on: September 28, 2017, 02:08:09 AM »
Of course the 69 is a different engine (as a complete assembly)  if your comparing just the 2V 302. Not saying that there is no way that Ford changed things and had the engines re-certified but that is allot of effort and dollars to spent to cover a few months of waining production. Would like to see mor evidence before I could accept it as fast. Just like other things we come across ;)
« Reply #20 on: September 28, 2017, 08:33:18 AM »
  Would like to see more evidence before I could accept it as fact. Just like other things we come across ;)
[/quote]
I would as well, I may see if Kevin Marti can add any incite
« Reply #21 on: September 28, 2017, 02:13:28 PM »
Did I miss something that Marti provided that suggested that the emission system was different? If not I'm unsure of what his access could provide.  We have to remember that Ford in 68 could not just choose to change related things but had to go through government testing, certification and approval processes
« Reply #22 on: September 28, 2017, 03:42:23 PM »
Marty (Rupp) mentioned he has a Marti (Kevin) Report that does not list the Thermactor. Perhaps Marti could find another example of a HCS manual trans, late build, that supports the heads found on Marty's example as being correct for his HCS.
« Reply #23 on: September 28, 2017, 10:28:52 PM »
Not sure if that helps since none of the 68 Marti reports I have list thermactor systems since it was not an option.  To be specific no 428 CJ, Small block with manual transmissions not 6 cylinders with manual transmissions or S codes no matter what time of year.
Examples from December through April
8R02J1107xx
8R01S1565xx
8R01S1565xx
8R01J15598x
« Last Edit: September 28, 2017, 11:43:21 PM by J_Speegle »
« Reply #24 on: September 29, 2017, 12:29:06 AM »
Ok I thought I had seen TE listed on a Marti report. I still may ask Kevin if he can see the information on emissions on the engine area of the build sheet. That may answer this question.
« Reply #25 on: October 27, 2017, 09:49:55 PM »
This car was sold new in Durango CO. We thought it would be a fun fall trip to drive it there. When we arrived we were disappointed to find that the building that held the original dealership had since been demolished. We did take this shot at the new Ford dealership. It was fun to think that this car had not traveled those roads in many years.
Marty
« Reply #26 on: October 27, 2017, 09:54:13 PM »
Marty
How long did the trip take?  Not a "just around the block" sort of trip :) Glad you made it safely
« Reply #27 on: October 28, 2017, 01:07:37 AM »
It was all most 1800 mile round trip around 15.5 hour each way. The car is a 3spd manual, non power steering and non power brake car that we drove south west from Denver to Durango. Those mountain roads were a challenge, now that is really driving the car. What was cool was I got home with 2700 miles on the oil change it had not used a quart of oil. Not bad for a 289 that has never been overhauled. The only real problem was the speedometer broke the first 50 miles. We used our GPS for ground speed.
Offline ramblewood390GT
« Reply #28 on: December 06, 2017, 04:18:04 PM »
This is a great example of this car, it looks like a time machine to me.
New guy needs help with: 6/20/68 San Jose 390GT
8R01S165XXX 65A M 2D 10F 53 G 5
