Restoring - General discussions that span across many different groups of years and models => Parts => Topic started by: Stangly on June 19, 2011, 04:24:10 PM
Title: Front drum brake question
Post by: Stangly on June 19, 2011, 04:24:10 PM
I'm trying to find some replacement gaskets for front drum brakes.  The first being the gasket that goes between the backing plate and spindle (ford part #2044)  The other one goes on the other side of the backing plate between the plate and the retainer (ford part #2026)  Is anybody reproducing these or do they need to be made.
Title: Re: front brakes
Post by: CharlesTurner on June 19, 2011, 07:33:51 PM
I had to make some of these last summer.  Check with Va Mustang or NPD though, they might have them.
Post by: Stangly on June 19, 2011, 10:52:45 PM
I ordered some from NPD but the holes don't line up.  I will try the other company you recommended.  Do you know what material and thickness the one between the spindle and backing plate is.  Thank you again for all the help, everybody on this site has been very helpful!
Post by: CharlesTurner on June 20, 2011, 08:55:54 AM
It's a thin ply material, if you have any of the original, should be easy to make.
Post by: Skyway65 on June 20, 2011, 09:07:03 AM
I used some lightweight foam packaging material.  Identical stuff to the originals that came off the car.
Post by: Stangly on June 20, 2011, 02:21:48 PM
The piece that is left is paper thin and does look like foam, I didn't think it could be cork or paper.  Thanks guys, I think my wife has some of that lying around.
Post by: CharlesTurner on June 20, 2011, 02:38:13 PM
That's another V8/I6 difference.  I6 has foam there and V8 has a semi-thick paper gasket.  Remember that the backing plates are not the same as well as the spindles (at least for 65-66)
Post by: Stangly on June 20, 2011, 07:44:54 PM
Charles,
Thank you for the clarification.  I will take a closer look at what is left of the original gasket, there appears to be only one ply of material left.
David,
Post by: Toploader on September 12, 2012, 03:34:57 PM
I have a question about the front backing plate to spindle gasket for my 65 V8.
But first a note on the grease baffle plate to backing plate gasket. I ordered a pair from a vendor who sells NOS parts. They weren't sold as NOS but as
"restored". They turned out to be "salvaged", all filthy with black old grease and apart some places. Useless. However, I noticed them to be of the same
foamy white material as the old ones on my car. So I assume this material to be OEM to early August 1964 SJ V8 cars? As mentioned above the material appears
on a close inspection to be exactly the same as the foam packaging material readily available (expanded closed-cell polyethylene). I couldn't lay my hands
on a sample, so now I have bought a 300-yard roll... :-\
About the circular spindle gasket, I have these from my car (see pictures).
The material is a sponge rubber type with brownish particles (cork rubber?). My question is: are these OEM/correct? Anybody knows exactly what material they are (in
case they are OEM)?
Post by: ChrisV289 on October 12, 2016, 08:30:58 PM
Does anyone have a picture of what this gasket looks like, NPD has part number 2044-1A but no pic and is currently out.  I didn't find much left of whatever it was when I removed the driver side backing plate.  Still have the driver side to go...
Title: Re: Front drum brake question
Post by: J_Speegle on October 12, 2016, 10:26:34 PM
Guess we should have asked you to clarify what year and other details you could provide before we started answering what we thought the question was ;)
Could you provide that so that we can focus in on what the original material likely was and how to help you
If its the paper like material like Charles I've always made my own (for rear end housing to backing plates also)
Post by: Scott302 on October 13, 2016, 09:32:31 AM
As to the 2026-1A retainer gasket, the bolt holes line up correctly on the V-8 plate from my 66.  I have the original gasket as well and that is a white open cell foam.
The 2044-1A gasket for the backing plate to spindle was supposed to be available by now but the original sample disappeared and I have not yet found another one.  That was also a white open cell foam material on my V-8 66.  If anyone has one of these laying around I'd be interested in borrowing it for a few weeks or I need accurate dimensions from an original.
Regards,
Scott
Post by: CharlesTurner on October 13, 2016, 11:08:40 AM
Scott, what assembly plant was the foam gasket on a V8 found?  I disassembled 3 '65 San Jose cars, all built in late January/early February.  The V8's had the flat gasket and the I6 had the foam.
Post by: outlawincorporated on October 13, 2016, 08:40:06 PM
CHARLES/JEFF.
image from a unrestored v8 late 66 Dearborn mustang with drum brakes.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Post by: ChrisV289 on October 13, 2016, 09:15:47 PM
Charles, would this hold true for Oct 64 as well?
Post by: J_Speegle on October 13, 2016, 10:37:54 PM
CHARLES/JEFF.
Question remains if he was looking for 65- 66- 67-68-69-70-71....... ?  details - Lots of years and variations.
Post by: CharlesTurner on October 13, 2016, 10:52:17 PM
Well, I couldn't say for sure.  Appears the foam was used on both.
Post by: Scott302 on October 14, 2016, 01:21:54 PM
Charles,
Forgot that this was from my Metuchen '66. Not sure of the build date.  Ser# 1853XX.
Regards,
Scott
Post by: ChrisV289 on January 10, 2017, 03:06:06 PM
Anyone know what the thickness of this material is? NPD isn't sure when they are getting a supply in and thought I would just get a sheet of cork material.  Comes in either 1/16 or 1/8 thickness.
Post by: J_Speegle on January 10, 2017, 03:14:20 PM
Believe its the 1 /16. That is the one I would use
Post by: ChrisV289 on January 10, 2017, 03:37:25 PM
Thanks Jeff!
Post by: ChrisV289 on January 14, 2017, 02:41:00 PM
Was able to separate it from the backing plate. Appears to be cork. Oct 29 64 build V8.
