Restoring - General discussions that span across many different groups of years and models => Interior & Trunk => Topic started by: J_Speegle on December 30, 2017, 01:45:33 AM
Title: 67-70 Trunk Wheel Well Lip Luggage Protector Strip
Post by: J_Speegle on December 30, 2017, 01:45:33 AM
Looking for input from owners who have their original strips still with their car. Helping out a member determining what color (black or gray) was used at which factories and time periods. If you have one - Could you please post
- When and where your car was built (VIN or just data will work)
- Body type
- Type/Color
- Length of the strip
For you unfamiliar with the strip, it was glued over the raised edge formed when the inner and outer rear wheel wells were welded together on the drivers side of the trunk. Don't want to use this thread to collect 65-66 data or the fuel wire retainer. Some of that has been done in other threads.
Here is a picture of an example of a black style
(http://www.concoursmustang.com/forum/gallery/9/6-301217004521.jpeg)
Here is a picture of a gray one
(https://www.concoursmustang.com/forum/gallery/9/6-271217170503.jpeg)
THANKS
Title: Re: 67-70 Trunk Wheel Well Lip Luggage Protector Strip
Post by: J_Speegle on January 02, 2018, 01:03:05 AM
Guess no one has found the time during this busy holiday period  but here is what I found after digging through a bunch of pictures.
(http://www.concoursmustang.com/forum/gallery/9/6-020118000136.jpeg)
Post by: sah62 on January 02, 2018, 08:40:28 AM
Jeff, do you know if this is the same material/profile that was used to provide a "pad" for the rear louvers on 1969 and 1970 sportsroofs? It it is, I have a good amount of the black material on-hand and can probably get the same material in gray.
Post by: Brian Conway on January 02, 2018, 11:18:09 AM
Over all length is a bit over 11" and grey in color.  Brian
Post by: specialed on January 02, 2018, 12:06:22 PM
scott  different material than louvers seal . I sent an original grey luggage strip to chris brown to have made since the grey is hard to find & often missing . He sent me a sample & they are excellent  but we are trying to figure out which cars got the grey vs more common black luggage protector so we know the concours correct market to sell the grey strips to  as the common black has been repoed years ago & show up on later cars being wrong color until now we have the concours correct grey to sell. Also tring to get the correct length  for year & body & from all my examples 69-70 (don't have any 68s) the 69 -70 fastback around 8 1/2" 69-70 coupe & convertible around 10 1/2" .  & I have never seen any black (original cars anyway) on any (Dearborn anyway) cars after 68.  These strips are glued on yellow glue & if not glued in place probly someone added them later so check for glue signs when documenting these cars.   Odd thing about this running color change from black to grey luggage strip protectors is the opposite on the battery heat shields since they had a running change from grey to black color!
Post by: sah62 on January 02, 2018, 01:54:50 PM
Ed, it's not the seal I'm talking about. There are small rubber "pads" on the louvers that keep the metal on the middle of the frame from touching the glass - here's a picture from the MPC (see the part circled in red). It looks like this might be the same material, just using a longer strip. If they are the same material using the same profile there's no need for a repro because I know of a commercial source that sells the stuff in long rolls. I just don't know if it's available in gray.
Does anyone have a picture of this strip showing what it looks like from the end? I expect that it's kind of like an upside-down "U" when installed.
Post by: specialed on January 02, 2018, 02:16:27 PM
we have a couple original grey strips on ebay  & have been selling them for years but are almost out of them that's why we repoed the grey version & its more correct copy than the  black repo that's been made years ago.   scott this luggage strip is very thin plastic like  where as the 2 louvers pads were thicker  type rubber different size also.  Call chris brown to get some of the new correct grey strips as they would be good to have on your lists of parts u make & sell.
Post by: J_Speegle on January 02, 2018, 02:47:28 PM
Believe the profile is different. "Sides" are a different height if I recall correctly. Don't have the Boss at home at the moment or I could post a side by side comparison.
Post by: JohnRB on January 02, 2018, 02:59:00 PM
Would be interesting to see some pics of the Windlace style used on 70 with the fuel evap system. Never seen it.
Post by: J_Speegle on January 02, 2018, 08:48:38 PM
i can do that for you John :)
Round corners, thick with the metal reinforcement and with texture/grain pattern just like windlacing around the side door and window openings
(http://www.concoursmustang.com/forum/gallery/9/6-020118194756.jpeg)
(http://www.concoursmustang.com/forum/gallery/9/6-020118194731.jpeg)
Post by: JohnRB on January 04, 2018, 11:01:50 AM
Perfect. Thanks. Just need to find some :o  Unobtainium over here!
Post by: J_Speegle on January 04, 2018, 01:39:37 PM
Would be very easy to make yourself in under a minute or so
Post by: JohnRB on January 04, 2018, 02:29:33 PM
Yes, if the right material was availible!
Post by: Bob Gaines on January 04, 2018, 02:44:17 PM
If you can't source some interior windlace from  a car locally you can order some from NPD . I think you even can choose from different textures.
Post by: JohnRB on January 04, 2018, 06:09:49 PM
Parts cars are far and few in Europe and I do prefer original parts!
Post by: Bob Gaines on January 04, 2018, 06:32:53 PM
Then I guess you have a choice, ether give up and only think of ways you can't or think outside the box and think of ways to accomplish your goal . Example call West Coast Cougar or other Mustang or Cougar used parts vendors and buy some used windlace . Best of luck with what ever you decide.
Post by: JohnRB on January 05, 2018, 06:10:56 AM
Bob
No worries. Another reader have already offered me some. Now I just need to find out how long it should be?
Post by: JohnRB on January 05, 2018, 07:10:36 AM
Was there a special style used in Dearborn? Color and "grain"?
VIN# 0F03R120***
Post by: specialed on January 05, 2018, 11:20:16 PM
john nothing special most windlacing is the same & always black on ca. evap cars i seen .     Just checked a jan 69 built low mile met. car & original grey strip still glued in place.
Post by: J_Speegle on January 05, 2018, 11:43:49 PM
Would be similar to what was used inside the cars in 70 not like the stuff used in the earlier years with the noticeable uniform pattern
Not sure if I have a close up of the later stuff. Maybe I'll check my Cougar
Post by: JohnRB on January 07, 2018, 11:35:18 AM
Post by: JohnRB on January 07, 2018, 11:35:41 AM
Post by: Bossbill on January 08, 2018, 05:23:07 PM
7R01C181xxx Black - 10.5"
7R02K18xxxx - Black - (only 2" was left)
0T02G160xxx - Missing, but yellow glue is 7.5".
I'll cleanup and use the C code parts car strip in the K car.
Post by: Mike_B_SVT on January 09, 2018, 12:46:46 AM
I was going to ask if this applies to Cougar as well.  Mine is MIA (Oct 1969, Dearborn build, California evaporative emissions).
Post by: J_Speegle on January 09, 2018, 03:46:57 PM
Since the rear wheel tubs are shaped differently from Mustangs I don't think they are needed. The Cougars have an edge on the inners that is formed to bend over the outer and not create the same blunt/sharp edge as in a Mustangs.   At least that is what I'm seeing in pictures of 68 & 70 Cougars
Post by: edwardgt350 on January 11, 2018, 03:47:24 PM
for 66 san jose car, were the black protectors glued on with yellow contact cement?
Post by: J_Speegle on January 11, 2018, 07:24:09 PM
Though that falls outside this thread - yes
Post by: cob428 on July 07, 2018, 06:51:55 PM
9T02M Black 10 5/8
9F02R Gray 11 1/8
Post by: specialed on July 13, 2018, 12:34:31 PM
those lenghts are what i see on coupe & verts as fastback 8 1/2''   are u sure the Met car had a black from factory original to the car?
