Restoring - General discussions that span across many different groups of years and models => Drivetrain => Topic started by: 68 S Code on June 23, 2011, 12:26:18 AM
Just trying to finalize detailing of some engine components before bolting them on. I would like to rent the "OK" valve cover stamp and the waterpump pulley stamp. I would pay a rental fee and all shipping to and from. I just need it for a a couple of hours so turnarounf would be quick. Hate to go to the trouble of having stamps made to use once. The waterpump pulley stamp I need is C8AE-8509-C same as on a CJ. Pm me if you can help. If not then how would I go about having stamps made? Where?
Forum member has offered to make me a set. Thanks for looking.
Sounds great glad you found some one - be aware that there are about four different sizes and styles of the valve cover one ;)
The OK is the one used on 68 1/2 CJ. Hope that's right.
Can anyone help to clarify what should be on a January Dearborn S Code valve cover and water pump and then where best to source (or how to make)?
The OK stamp (though there are at least 5 different variations that I've seen on different years - different engine plants) is pretty standard by 68 on many engines
The water pump pulley stamp was only used on some pulleys IMHO likely due to a different supplier, that did not get the engineering number stamped into the metal. Only seen a few cars with these
Don't know where you would purchase them and (just for me) I tend to find that many lack the correct sizing, font, spacing ... that I'm looking for so I spend many hours in Paintbrush and Photoshop redrawing my own (did computer based graphic arts and layout for a fair number of years ;)
Jeff:
Do you happen to have a photo for what should be correct for a Jan 69 Mach 1 S Code and I can try it from there. Would the 390 stamp be the same as the 428CJ stamp?
Jeff:
Still away from my picture collection (not ignoring the post ;) I"ll double check when I return
If I forget just remind me please
