Restoring - General discussions that span across many different groups of years and models => Processes, Products & Techniques => Topic started by: MWM on March 10, 2012, 01:52:08 PM
I am working on my 1965 fastback. The trim that goes along the windshield and rear window is bent. Any advise on how to straighten it out without scratching or making it worse?
Thank you!
I guess it depends on how its bent. Mine were more dinged and dented rather then bent. I just hammered out the dents making some anvils out of hard maple to match the contour. Then sanded it smooth using a block of wood starting at 120 grit up to 2000 grit. Then buffed and polished. They didn't come out perfect. You can still see waves if you look from the right angle. My drip rail moldings were more then I could handle so I have some one else working on them. Its just taking him a really long time.
If its a soft bend maybe you could get away without polishing by applying pressure in the right spots with some thing soft but if you start hitting it it will scratch and dent.
Thank you Steve!
I like the idea of using a block of wood. Wish me luck!
http://www.youtube.com/watch?v=wTxR8LB9iek
Worth the time to view all 3 videos !
Mark
Thanks for posting Mark :)
