Author Topic: 68 Outer Bumper Arm: Rubber Piece  (Read 3714 times)
Offline Sunlitgold68
« on: July 09, 2010, 01:08:14 PM »
Anybody know the purpose of the 4 or 5 inch ribbed rubber piece that slides over the end of the outer bumper support arm on the 68's? I have 1 of mine, did both arms have these pieces? Just curious as to what they are for.
8T01C204XXX
Built May 14th, 1968
Offline cobrajetchris
Re: 68 Outer Bumper Arm: Rubber Piece
« Reply #1 on: July 09, 2010, 02:04:50 PM »
I have the same part on my 69-70 models and always wondered what it was for as well. I believe they were all on the rt. side only on my cars. CHRIS
CHRIS KNOBBE
69 MUSTANG COUPE, DEARBORN BUILT 06/10/69 OWNED SINCE 1978
70 BOSS 302 MUSTANG, DEARBORN BUILT 10/24/69 OWNED SINCE 1987
69 R CODE MACH1 AUTO, DEARBORN BUILT 10/10/68 OWNED SINCE 2006
69 R CODE MACH1 4 SPEED (factory black) SAN JOSE BUILT 12/30/68 OWNED SINCE 2007
« Reply #2 on: July 09, 2010, 03:58:53 PM »
I believe they were there to prevent metal to metal contact between the bumper arm and valence/headlight assy.  On original arms there is a metal tab to keep the sleeve from sliding down.
« Reply #3 on: July 09, 2010, 04:22:47 PM »
I noticed those tabs, do you know if both sides had them or just 1? Can't believe mine never fell off in 285,000 miles..... will definitely clean the piece and reinstall.
8T01C204XXX
« Reply #4 on: July 09, 2010, 06:23:26 PM »
Always seen them on both sides.
Online Murf
« Reply #5 on: July 09, 2010, 08:02:03 PM »
You guys made me curious!  Just looked at our 68 CS ( a pretty good, untampered with car in most respects) and it has them on both outer bumper brace tubes.  They consist on this car on a length of rubber hose, very much like heater hose.  Each one has a ribbed section and that is where the "split" is made.  They are now a rather oblong shape but could have been round when they were new.  The split follows the ribbed area and appears too precise to have been hacked up by someone.  They are easy to remove and it is hard to imagine that they have remained in place for 42 years.  Am unable to post images here but if anyone wants a picture I will remove them and email a photo to someone who will post it.  Anyway, at least on this particular car the rubber hose is indeed on both sides and toward the forward edge of the tubular brace.
John Murphy
« Reply #6 on: July 10, 2010, 12:02:34 AM »
I'm in need of 1 original if anybody has an extra. thanks
8T01C204XXX
Offline gtamustang
  • CPM
« Reply #7 on: July 10, 2010, 09:58:00 AM »
John,
I believe I have one that we can use on your restoration.
Regareds,
Pete Morgan
« Reply #8 on: July 10, 2010, 10:44:09 AM »
Sounds good Pete, thanks
8T01C204XXX
Offline dkknab
« Reply #9 on: July 16, 2022, 10:02:59 PM »
Thought I would add to this old thread that I stumbled upon searching info about heater hoses.  These are the split hoses on the front bumper supports.  I have both of mine.  They were painted over some when the car got a respray. The one pictured on the left appears to have sound deadener spayed on the bottom.  They are also different lengths.
PS it's even listed on the assembly manual as C7ZB-17B947-B insulator.
« Last Edit: July 16, 2022, 10:33:41 PM by dkknab »
David Knab
289 2V, AT, PS
Nugget Gold Interior
« Reply #10 on: July 17, 2022, 03:00:46 PM »
You may have stumbled upon them while searching info about heater hoses but do not be fooled into thinking that they are made from heater hose. ;) They are made from a different diameter then heater hose. Used is your best source for replacements. The drain hose from fastback vent boxes look to be a exact match but they are as hard to find and consequently pricy to use as donors. Of course heater hose is what the majority use to replace missing ones although not technically correct.
Offline dkknab
« Reply #11 on: July 18, 2022, 10:03:45 AM »
Thank you Bob. By the way my car while it had the split insulators on the supports, it did not have the 2 smaller insulators on the inner bumper supports.
Speaking of which what should be the finish on the front bumper supports? Mine are partially black and partially body color of which I assuming happened when the body was repainted. Should they be all black? Are there any pictures I could refer to?
I did see on this unrestored car pictures https://www.concoursmustang.com/forum/index.php?topic=5405.msg30574#msg30574 the supports nearest the frame are black.  Does that extend all the way to the bumper?
« Last Edit: July 18, 2022, 10:12:36 AM by dkknab »
David Knab
289 2V, AT, PS
« Reply #12 on: July 18, 2022, 02:54:13 PM »
They are semi gloss black .They were added after the car was painted so there should not be any body color overspray.
Offline dkknab
« Reply #13 on: July 19, 2022, 10:40:23 AM »
One other thing related to the front bumper brackets.  What is the finish of the bolts attaching the brackets to the frame rail?
From this same car,  https://www.concoursmustang.com/forum/index.php?topic=5405.msg30574#msg30574, they appear to be unpainted.
« Last Edit: July 19, 2022, 10:51:49 AM by dkknab »
David Knab
289 2V, AT, PS
« Reply #14 on: July 19, 2022, 11:46:05 AM »
You should have assemblyline manuals given your detailed questions. The bolts and the finish designations are shown in the illustrations.
