Author Topic: 69 Mach1 rear leaf spring code  (Read 1339 times)
Offline nealepmach1
« on: February 25, 2018, 04:16:54 PM »
I have 69 Mach1 with this part number stamped on the rear leaf springs. just want to know if they are original items, the car is a 351 4v, FMX, 9 inch rear axle car. The spring part number is C9ZA 5556C 0870 or 9.
1969 Mach1, 351W4v, FMX.
1969 Cougar, 351W4v, FMX.
1973 Fairlane 500 ZF(Australian) 351C.
Re: 69 Mach1 rear leaf spring code
« Reply #1 on: February 25, 2018, 04:53:45 PM »
Don't have any personal sightings to confirm but other documents suggest that these may have been one of the rear springs used on cars similar to what you provided
Offline nealepmach1
« Reply #2 on: February 25, 2018, 05:16:40 PM »
Thanks Jeff, I will get the number off the other spring to see if they are similar.
« Reply #3 on: February 25, 2018, 05:19:53 PM »
Would guess that the date is hard to read since the one you posted does not match the expected pattern - Julian calendar
Offline nealepmach1
« Reply #4 on: February 26, 2018, 09:49:11 AM »
The codes are fairly clear, it's the last digit, not sure if it is a 0 or 9.
Offline nealepmach1
« Reply #5 on: February 26, 2018, 09:53:43 AM »
Image of number
« Reply #6 on: February 26, 2018, 01:37:32 PM »
I see a very faint double-strike of the numbers below the obvious one; in particular, the RH side dimple is quite prominent and a "7" just to the left of it.  What I see to the right of the upper 7 may be an 8 and offset upwards.
« Reply #7 on: February 26, 2018, 02:47:55 PM »
Image of number
Thanks - you have one of those springs (from a different supplier)
Just for the record where was your car built?   Think I know but will wait for you to maybe confirm ;)
Offline nealepmach1
« Reply #8 on: February 26, 2018, 05:50:56 PM »
I will photograph the other spring at the weekend and will try to get clearer images, thanks for your help.
Offline nealepmach1
« Reply #9 on: February 26, 2018, 06:00:22 PM »
I have this letter from Ford which has some basic info on my car.
« Reply #10 on: February 26, 2018, 06:03:35 PM »
Original 69 Export car. Very cool
Offline nealepmach1
« Reply #11 on: February 26, 2018, 06:15:13 PM »
I guess my car is no different from a non export Mach1. It still has its original interior including all of the rear fold down seat assembly in fairly good condition. I have the paperwork for all of the owners in the UK from new, the only thing that I haven't been able to find is the importer dealer, I know in the '60's in the UK there were a few specialist American car importers who imported car's for private purchases, as far as I know no UK Ford dealer's were selling new Mustangs.
