Restoring - General discussions that span across many different groups of years and models > Body, Paint & Sealers
front fender sound deadner
J_Speegle:
--- Quote from: 66RavenGTCoupeAgain on June 05, 2017, 09:04:48 PM ---Just what I was after. Would the application pattern be much different for a 10/20/64 SJ car?
--- End quote ---
From the example I posted - Yes If the worker choose the bottom of the fender might have had no sound deadener and each inner panel could have received only a single pass of the wand maybe 10" side and a foot long
--- Quote from: 66RavenGTCoupeAgain on June 05, 2017, 09:04:48 PM ---Just a side question: Did convertibles have the sound deadener on the inner rear side panels in the trunk?
--- End quote ---
Yes all body styles were suppose to received a section of the inner quarter panel with the sound deadner. Often 3-4 passes with the wand
--- Quote from: 66RavenGTCoupeAgain on June 05, 2017, 09:04:48 PM --- Also, was the deadener in the area where the rear quarter windows wind down into done at the same time as the rear wheel arches?
--- End quote ---
If it got missed it should have been picked up by the multiple inspectors. Thats not what was common nor playyed
Not over the wheel arches - rearward of the arches in the trunk area, Often but not always was the surface behind the rear quarter windows would get a short single pass commonly
brennancarey:
i am just wondering what product and application is everyone using on the front fender sound deadner ?
I know on the rear wheel house success has been obtained with Spectrum Sludge, but thats a manual approach with a brush. So on the front fender with everything installed what is the product and procedures that are been used as you cant apply in these areas with a brush surely ?
thks!
CharlesTurner:
I've been using Lord Fusor sprayable seam sealer, 805HD. Requires a special gun to spray, I borrow my body guy's Wurth one.
brennancarey:
--- Quote from: caspian65 on June 06, 2017, 11:18:24 AM ---I've been using Lord Fusor sprayable seam sealer, 805HD. Requires a special gun to spray, I borrow my body guy's Wurth one.
--- End quote ---
Ok great, does anyone know if Wurth have a similar product to the Lord Fusor as I can get Wurth products but not Lord Fusor in "my neck of the woods" ?
67gta289:
This is what I use
[#] Next page
[*] Previous page
