Restoring - General discussions that span across many different groups of years and models > Drivetrain
axle tag
(1/1)
c9zx:
I have figured out that the "plant code" 955B indicates a 3.25:1 gear set, non locking differential. Does 955A indicate same ratio with locking differential? 1972 Q code, 9 inch differential.
Thanks, Chuck
svo2scj:
NO
According to Marti Tagbook the suffix (added after 1969) is for internal engineering change
Mark
WFB-C or C2 is 3L25 (locking) WES-AD2 is 3:25 open
c9zx:
Thank you for the information. By any chance does the tag book indicate what the "plant code " is for 3.25:1 28 spline locking? The reason I ask about the A meaning locking is the 2 Boss 351 axle tags I've seen have an A suffix.
Thanks Again,
Chuck
svo2scj:
The the "plant code" 900 series is Mustang/Cougar.
IF it is 28spline then it should be WES code (and not locking)
Mark
P.S. Again the "suffix" is called out as internal engineering change (doesn't matter if Boss 351 )
c9zx:
Chuck
