1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: 1967 eight barrel on March 07, 2018, 02:41:46 AM
I had my original master restored and went to install it. I noted as I tightened down the rear line the tube furl looked normal. ( A small gap that still had exposed threads after it was tightened. When I tightened the front it tightened up all the way to the machined surface. It doesn't seem to be leaking, but it is of concern to me.
Is the inverted portion inside the master a serviceable item? If so, who would had one? What is it called?
I thank you for the help in advance.
-Keith
The first picture is not correct, but intended to be useful to determine what part numbers you are looking for.
The 2169 is designated a "Piston - Brake Master Cylinder".
These were not serviced individually, they were supplied in the 2004 repair kits.
The second picture denotes what is included in the 2004 repair kit for the 68 mustang with PDB.
The third picture covers 65/66 in detail, but for 67 there is simply one line that calls out the C7ZZ-2004-A kit, with no detail, other than it is a 1" bore.
The previous information was from the 60-68 MPC. The 67 one year only has the same level of information.
I see that in the current NPD manual there is a 2004-4 rebuild kit that covers many years. In the price column is the text "CALL".
John,
It's the item lined closest to the 2004 identification in the repair kit. When you tighten up the line, the flair would seat against it.
The flare seats are often supplied with rebuild kits. I believe they supply the smaller one only in some instances. I just looked inside the cylinder I built for my 67 and I see I have installed a new one in both so obviously, they are out there. I sourced my rebuild kit from my local NAPA store. I have no recollection of chasing down the flare seats for my master cylinder so I assume they arrived with my rebuild kit.
I did have to chase down the new seats inside my power steering control valve and power steering cylinder ram, but that is a different subject.
The NPD kit is NLA. I just got off the phone with them. I will call NAPA when they open.
-Keith
Keith, Some master cylinders have a check valve behind the flare seat made of rubber this is a consumable also that should come in the kit.
https://www.amazon.com/Raybestos-MK549-Professional-Master-Cylinder/dp/B000C71NB6
Picture shows 2 tube seats and 2 check valves. The seats look like they are the same (small) size, and the PDB master should have only one check valve.
The photo may be inaccurate. Has any one used this kit?
Looks to be what NAPA sells # UP549, no doubt NAPA re-boxes the Raybestes product. I looked up the 67 Mustang listing on my shop's Napa Prolink and came up with this image:
https://s7d9.scene7.com/s7viewers/html5/ZoomViewer.html?stageSize=500,400&asset=GenuinePartsCompany/359517
As I mentioned earlier, I did NOT recall having to outsource the flare seats so they should be correct. The instructions included with the kit explain that some cylinders will not have all parts seen used. The check valves are most likely for 4-wheel drum brake usage applications, other than Mustangs
Why I didn't think of Amazon is beyond me. They are not being produced at the moment, but I did find one at Rock Auto. I just ordered it...
How do you pull the seat from the master?
NAPA shows one at their Buffalo (DC) location and 8 at their McHenry Ill. (DC) location...they can get them but UPS charges may apply ;)
They provide a screw to thread into the seat and axtract it like a dentist does an impacted wisdom tooth!
Keith - In the picture there are 2 screws - use them to tap into hole in seat then grab and pull out.
Kurt.
The NAPA here close claimed there are NONE to be had, as did O'Reilly. There are few real parts stores anymore. The rebuild on my booster also has me less than thrilled. I spoke to Booster Dewy and he claims he can make them function better in low vacuum environments. So I will overnight the booster to him while I refurbish the Bendix Master.
Speaking of trash, I purchased replacement rear wheel cylinders from O'Reilly. When I went to bleed them the bleeders were made with a metal so soft I rounded them off on both sides just breaking them loose with a line wrench. Chinese trash!
Thank you! I expanded the picture and saw the self-tapping screws. Makes perfect sense now.
-Keith
Keith : About a year or year and a half ago, I started to get things ready to rebuild my Master Cylinder for my Power Drum Brake 67. You didn't note if yours was Manual or Power Drum, but they are virtually the same ; both use Bendix Casting 2227061, only the internal parts are different. I had an NOS Ford Kit, C7ZZ-2004-A, (Manual Drum would be C7ZA-2004-A), but wasn't sure if the rubber might be hard, so to be on the safe side, I thought that I'd get a "new" Kit. I don't know how much you looked for these, but they are not as easy to come by as they were 20 years ago. I believe that is because that for just a little more money, one can buy a rebuilt Master Cylinder, and in some cases, a new one. This is great for those that just want to basically bolt something on, and "go". However, this does not help those of us that want to use the original casting and rebuild it.
Interestingly, I found mine also at Rock Auto. I compared the parts furnished in the Ford Kit with those in the Raybestos Kit (see first 4 pictures). Both had the same 2 pistons, 2 check valves, 2 check valve springs, 2 tube seats, snap ring, O-ring for the piston stop bolt, and even 2 screws for use in removing the existing tube seats. The only thing that the Ford Kit had that the Raybestos Kit did not have, was a new piston stop bolt.
I have included several pages from the 1967 Preliminary Shop Manual, that contains several things not found in the "regular" Shop Manual, that you may find of use.
Bob
P.S. I have tried to Post this Reply 6 times, both with and without "Preview", and keep getting "This website cannot be displayed". Therefore, I am only going to Post the first 4 attachments here, and follow with another Reply with the remaining 5 attachments.
Additional 5 attachments from 1967 Preliminary Shop Manual (sorry for the quality, but it won't let me attach them in 600 dpi.).
Bob
I know your build goes back and forth between assemblyline and personalization but thought I would mention that NPD sells a bleeder designed for use with the modern larger bleeders and has machined the wrench side portion to have the appearance of the smaller assemblyline bleeder. This gives the original look when using a auto parts store wheel cylinder. Just thought I would mention it.
Bob Gaines:
I ordered the bleeders this morning! Thank you!. You know I used to buy Wagner. I don't even know if they are in business anymore. I finally got a set of the correct nails for the rear shoes and I didn't have to compress the hold downs at 90 PSI to get the retainers on!
Thank you all for the pointers and help!
-Keith
Is there a difference between the master for power Disc/drum and just power drum? The MK488 is what they shipped me. I see MK549 in the link above.
Absolutely different. The Power Disk/Drum MC used Bendix casting # 2227161, while both the Power Drum and Manual Drum used the same casting # 2227061 (as I described in my previous Reply). Thus, the Raybestos Kit for Power Disc/Drum is MK 549, while the Kit for Power Drum is MK 488.
Bob
Rock auto didn't specify. Just listed power. I guess I'll be returning it.
If you are ONLY needing the seats, you may still be OK
Rich, I went ahead and pulled the trigger on Amazon. No since in throwing away the rest of the kit.
Rock Auto lists both 488 and 549
https://www.rockauto.com/en/catalog/ford,1967,mustang,4.7l+289cid+v8,1332313,brake+&+wheel+hub,master+cylinder+repair+kit,1840
Bob
Yes, I can confirm the DRUM version master cylinder from a power brake conversion kit I have on hand, has indeed the 2227061 casting. Pictures posted in a FOR SALE ADD today.
Keith : I think you made the correct choice. Not just because of the fact that you'd be throwing away perfectly good internal parts that you couldn't use, but also because of the seats themselves. In your specific case, it sounds like you have your known original Master Cylinder, and would thus be able to confirm that the Kit seats matched those in your existing MC. However, for others reading this thread, that may not be the situation. Case in point ; on my '67, which my Dad purchased from the original Owner in 1981, at some time, the original MC was replaced ; either by the PO, or even possibly by my Dad (although I don't remember him doing so). I, wanting to replace the Wagner MC with the original Bendix one, sought to find an original Bendix casting. In my case, with original Drum brakes, I was also going to add the Optional/ Accessory Booster. As I noted previously, the Manual Drum Brakes and the Power Drum Brakes both used the same 2227061 casting. I purchased one from one of our members a couple years ago, and when disassembling it, compared the parts with those furnished with the original C7ZZ Kit that I had, as well as with those on the Raybestos Kit. All of the parts in the two Kits seemed identical, while the tube seats were slightly different ; the orifice size in the C7ZZ Kit being 0.0116", and those in the Raybestos Kit being 0.110". However, the seats in the MC that I had purchased, were 0.089". While 0.021" diameter may not sound like much difference, since pressure is a function of Force divided by Cross-sectional Area, this could make a difference of almost 35% in the resulting pressure. While this may or may not affect how the system actually functions, one would think that you would want to replace seats that had an orifice size at least close to the original ones.
Being curious, I wanted to find out just what application(s) this Bendix casting (2227061) might have had. The source I had, showed that this casting was used on 1967-72 Fords and Mercurys, and 1967-73 Fords and Mercurys, with the two applications showing different Master Cylinder assembly Part Numbers ; one for Manual Drum Brakes, and the other for Power Drum Brakes. Based on this, plus the fact that the used MC that I purchased came with a rubber boot and brake push rod, I concluded that it must have come from a Manual Drum Brake application, Mounting and tube nut sizes for the lines were identical in both cases.
While checking on castings, I also decided to check on the one used for 1967 Mustang Power Disk Brakes (2227161). In this case, things become more complicated, especially if one does not have a known original with which to compare (thus the reason for this long Reply). The 2227161 casting was used on 1967-72 Mustangs, 1967 Ford Trucks, 1967-71 Chevy and GMC Trucks, and 1967-70 Dodges and Plymouths (again, each set of applications shows a different Master Cylinder assembly number). Thus, besides possible internal differences, there are likely physical differences in mountings and in tube nut sizes.
So, a "word for the wise" ; if taking Richard's suggestion, "If you are ONLY needing the seats, you may still be OK", just be sure you have a known 1967 Mustang Disk Brake MC with which to compare, and even more importantly, if you don't have an original, and are seeking one, be sure that it came from a 1967 Mustang. At least through 1968, the Power Drum and Power Disk Brake Master Cylinders were all "unique" to 1967 Mustangs, all carrying a C7ZZ Part Number, and the Manual Drum MC being unique with a C7ZZ Part Number until January 9, 1967, at which time it was replaced by C7AZ-2140-M.
Hope this will help some from ending up with incorrect parts.
Bob
To add to the discussion, the identification of a 67 and many 68 Mustang disc brake master cylinders can be done by observing the stop bolt. It is typical to see on 67 and many 68 Masters a small hex head stop bolt underneath vs the cone shaped stop bolt of later years.
+1 And, also on the Drum Brake Master Cylinders.
Bob
According to the 1967 Shop Manual the factory master cylinders had a code letter stamp on the side or on the end for easy service identification. For Mustang/Cougar power disc code M, power drum code X, standard drum code T.
See shop manual brake section pp 2-9 thru 2-11 and Fig. 3.
My 67 GT350 has its original and there is an M stamped on the forward end.
Kurt
The bore of the power Disc/Drum Vs. Drum/Drum is different. 1/16" larger on the Disc/Drum. That solves that...
This is an old post but applicable to my issue...I ordered a master cylinder rebuild kit from NPD this week (12/11/2023) and did not receive the check valves nor the seats. Application is 1967 Mustang, Power Disc Brakes. Kit I ordered was 2004-4...no one seems to have the MK549 kit.
Anyone have a source for these items (seats and check valves)?
you may get more attention if you place an ad in the parts wanted section. good luck in your search.
I finally gave up looking for deals and bought an original NOS kit from JD Larson at http://www.allclassicmustang.com/
Have you tried NAPA? Part number UP 549 should get you what you need.
Contact this company for your seat needs.
Frank
https://www.musclecarresearch.com/brass-tube-seat?v=181
Thank you for the help. I tried online with Napa for the kit, it states unavailable. So I called and the guy said UP 549 returns brake shoes. I asked for him to look it up by the application...he said it is not available.
I have left a message with Scott at Muscle Car Research, regarding the seats. If they have them, not sure what to do about the check valves.
Thank you.
