Author Topic: '66 wiper motor grease  (Read 2072 times)
Offline 66nag
« on: August 09, 2021, 06:51:55 AM »
Just needing to clean up a '66 wiper motor - and after 50+yrs, the old brown grease has dried up some what.
The Workshop Manual recommends "Sun Prestige Grease" (but Google no findie!)
What grease would you recommend to replace?
Lithium? Bearing grease? Multipurpose?
If so, any brand better than another?
Thanks in advance,
Bj
Offline Deuce
Re: '66 wiper motor grease
« Reply #1 on: August 09, 2021, 04:10:29 PM »
Sunoco automotive Prestige Grease
Found on eBay: https://www.ebay.com/itm/Vintage-Sunoco-Automotive-Prestige-Grease-Lubricant-1-Lbs-Can-Container-/184545312065?
A general purpose grease...
Choose your favorite GP grease from today's many brands?
« Last Edit: August 09, 2021, 04:12:53 PM by Deuce »
Deuce
2008 Premium GT Coupe, 5-speed, rear spoiler delete, HID headlamps, well-optioned, Flat Rock built Oct 23 2007, RC 72
Offline 66nag
« Reply #2 on: August 10, 2021, 06:16:04 AM »
Yes!
The grease in my wiper motor looks about as old as that tin!!!  ;D ;D ;D ;D
Thanks - I just didn't want to put something in there that was going to clog it up, or melt in the heat down here in Aus.
I'll look for a GP grease in a nicer colour! ;)
Kind regards,
Bj
« Reply #3 on: August 10, 2021, 09:53:11 AM »
You will want to clean all the old grease residue out and use a modern general purpose grease. These days the synthetic red grease is typically on every store shelf. In aviation we have used Mobil #28 red synthetic grease for perhaps the last 60 years. The automotive version is sold as Mobil #1 grease.
Sunoco is still in business, their version is here:
https://sunocolubes.com/product/sunoco-tacky-red-grease
What you don't want is anything containing molybdenum which is typically found in "Disc Brake Type" greases. You don't want black or white (Lithium) grease. You want GP red or brown grease. Usually that will be the cheapest on the shelf.
Offline 66nag
« Reply #4 on: August 11, 2021, 08:09:57 AM »
"Usually that will be the cheapest on the shelf"  -   makes a pleasant change!  ;D ;D ;D
Thankyou - your advice is much appreciated!
I'll look for Mobil #1. ;)
(As luck would have it, Ampol has just made a comeback here Down Under, and apparently "Ampol Limited and ExxonMobil have entered into a marketing alliance, where Ampol will blend, distribute and market Mobil lubricants in Australia. ExxonMobil owns the Mobil brand, following its acquisition of Mobil Oil in November 1999. Ampol will supply Mobil lubricants to retail and business customers through a combination of direct and distributor channels. The manufacturing, distribution and marketing conversion to Mobil lubricants will commence in 2021 and will take approximately 12 months to complete."
How's that for timing? 8)
