Restoring - General discussions that span across many different groups of years and models => Misc Items => Topic started by: G Wood on October 28, 2012, 05:43:17 PM
I am mounting my brake lines along the trans tunnel to the rear of the car. I have the AMK mount kit that has 4 silver colored clips with a small rubber gasket to mount the line along the tunnel. How do these mount or fasten into the round holes that are in the bottom pan? Any help is appreciated.
I've always inserted them into the hole, pressing upward with a pair of pliers while not squeezing them. Once I feel they are fully seated and in as far as they will go I squeeze the two ears or wings and the other ends spread out inside the car holding the clip in place.
Thanks guys. Should the wings run parallel with the trans tunnel or vertical to the tunnel?
Checked a few 69 Dearborn resources and they appear to be vertical to the tunnel - or at least the ones I can make out were
Thanks for the quick responses.
Garth
Had a couple of 69 Dearborn pictures handy. Lucky though not something I get/take allot of detail pictures of ;)
