1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year > 1967 Shelby
Automatic transmission inspection plate and engine block plate finish?
Kyle Zammit:
Hi all,
I am looking for the finish of the automatic transmission inspection plate and engine block plate to transmission.
The inspection plate was bare metal with no blue overspray please?
The engine block plate was installed on the engine block with no starter and then were painted together with the engine please? They had overspray blue on the side of the engine please?
Bought for a 67 Shelby GT500 automatic.
Thanks Kyle.
J_Speegle:
Engine plate was attached to the engine block when the engine was painted so like small blocks the plate would have received direct application of engine blue to the edges and cut outs that the block did not protect from the spray along the top and sides while at the bottom the forward facing surface would have received blue paint directly as the painter tried to spray and cover the block and oil pan completely and try not to full cover the area where the starter would attach to insure a good ground when its attached later. So on the face you would typically see a nice coat at the upper edge of the plate where it meets and since the plate does not extend much pass the bottom rear edge of the block it was typically pretty much fully painted along that edge.
If you don't paint it it will stand out and can be seen from just about any angle if someone looks
Kyle Zammit:
--- Quote from: J_Speegle on April 11, 2023, 05:03:59 PM ---Engine plate was attached to the engine block when the engine was painted so like small blocks the plate would have received direct application of engine blue to the edges and cut outs that the block did not protect from the spray along the top and sides while at the bottom the forward facing surface would have received blue paint directly as the painter tried to spray and cover the block and oil pan completely and try not to full cover the area where the starter would attach to insure a good ground when its attached later. So on the face you would typically see a nice coat at the upper edge of the plate where it meets and is near the oil pan fading away at it travels to the bottom edge. Remember these spray guns put out allot of paint and allot of over spray and originals we see today are likely missing 50% of the paint that they originally had due to age, cleaning and the elements.
--- End quote ---
Thank you so much Jeff. Any information on the inspection please?
J_Speegle:
Reworded a section of my reply after reminding myself how little of the plate is exposed on the face
"So on the face you would typically see a nice coat at the upper edge of the plate where it meets and since the plate does not extend much pass the bottom rear edge of the block it was typically pretty much fully painted along that edge. "
--- Quote from: Kyle Zammit on April 11, 2023, 05:16:00 PM ---Thank you so much Jeff. Any information on the inspection please?
--- End quote ---
Inspection cover is semi-gloss black on all surfaces
Sorry is a bit dirt but original and the paint as well as other details are visible
Addition pictures are in the unrestored picture threads - identified as a late 7R207xxx S code San Jose fastback if you want some additional pictures of details. Many relate to your car aslo
Kyle Zammit:
Thanks for everything Jeff. I appreciate for helping me.
[#] Next page
