1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: Steve.chatman on February 25, 2018, 04:25:55 PM
Is the Alternotor ground bolted to the same place as the battery ground, on the side of the block? My assembly Manuel doesn't say.
Believe it does attach using the same attachment point and hardware with the thick battery/ground cable that goes to the battery
To add to the conversation , the correct big block alternator harness ground eyelet is larger to accommodate the larger BB ground bolt diameter. The smallblock alternator harness ground eyelet on the other hand is smaller to fit the small block smaller diameter ground bolt.
Thanks guys!
