Author Topic: 554 J Decal  (Read 3790 times)
Offline cobraboy
554 J Decal
« on: April 03, 2011, 04:39:05 PM »
I have a 554 J decal for the front of my engine. I read it should go on the flat area near the waterpump.
Does this mean on the actual block on the front face of # 1 cylinder ?.
I have a raised rectangle plinth there that would mean placing the decal dificult. If this is the location are there alternatives ?
Thanks.
13th April 1965 Dearborn K GT on the other side of the pond.
Re: 554 J Decal
« Reply #1 on: April 03, 2011, 06:21:45 PM »
Did your car originally have a cast iron or aluminum water pump?
Offline cobraboy
Re: 554 J Decal
« Reply #2 on: April 04, 2011, 01:32:27 PM »
Engine is level 7  - Aluminium pump.
Scheduled build date 13 R Dearborn 1965 K GT
« Last Edit: April 04, 2011, 05:19:58 PM by cobraboy »
Offline Ivygreen65
Re: 554 J Decal
« Reply #3 on: April 04, 2011, 04:29:13 PM »
Didn't change level 7 make the change to a cast iron water pump?  I'm at the office and don't have Bob Mannel's book close by, so I'm going from memory.
Offline cobraboy
Re: 554 J Decal
« Reply #4 on: April 04, 2011, 05:18:30 PM »
Cast iron pump introduced at level 8, June 1965.
Offline Twilight65
  • Gold Level Subscriber
Re: 554 J Decal
« Reply #5 on: April 04, 2011, 06:47:00 PM »
So on an aluminum pump, would this have been the location of the decal?
Dave
« Last Edit: April 04, 2011, 06:49:38 PM by Twilight65 »
Re: 554 J Decal
« Reply #6 on: April 04, 2011, 08:38:27 PM »
Matches some original examples, yes.  But, obviously applied after the engine was painted.
Offline cobraboy
Re: 554 J Decal
« Reply #7 on: April 05, 2011, 02:45:11 AM »
Dave and Charles
Thank you for the info - just what I needed.
Mark
Offline KCodeK
Re: 554 J Decal
« Reply #8 on: April 07, 2011, 03:06:20 PM »
Where did you get the decal?
I'm not a judge, nor do I play one on TV, but I have seen this decal behind the alternator on the block.
« Last Edit: April 07, 2011, 03:08:19 PM by KCodeK »
Offline ChrisV289
Re: 554 J Decal
« Reply #9 on: April 07, 2011, 03:43:57 PM »
NPD carries them.  The decal number should match what is on your metal engine tag.  Provided it is the original tag
2009 V6 Mustang Coupe
Re: 554 J Decal
« Reply #10 on: April 07, 2011, 03:49:18 PM »
That is where it would be on a 67 Mustang big block.  Late 65(cast iron waterpump) and 66-67 small block had it stuck across the coil long ways. Bob
Re: 554 J Decal
« Reply #11 on: April 07, 2011, 04:04:30 PM »
NPD carries two varieties. Request the ECS brand. They are the most faithful to the originals. Bob
Offline cobraboy
Re: 554 J Decal
« Reply #12 on: April 07, 2011, 04:56:59 PM »
I got the decal from ECS.
