1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: MustangAndFairlane1867 on June 25, 2017, 01:22:14 PM
In my boxes of parts I've come across two different front cross-member supports. Notice in the attached pictures that one of them has two large (thick) washers tack welded to the supports ends where the attaching bolts would pass through. I don't know if this was factory, or maybe performed for unknown reasons by a previous owner. I'm in the process re-assembling at 1965 K code fastback (San Jose/2.16.1965) that's been apart for several years and at this point I'm unsure which of these cross-members is correct for my project (though I suspect it's the cross-member without the large washers). Any thoughts? Thank you, Ron
For judging purposes, go with the "stock" piece. The one with the washers would be accepted if accompanied with documentation.
Ron, go with the stock cross member (no washers) are my thoughts . That is if you want factory look. The other cross member is a owner modified item IMO. I am unaware of any benefits that the added spacers would give even if you didn't want a stock look. I am however curious of what the spacers would could have been for.
my 2cents on the spacers..........someone did not have the proper bolts for this application. have seen similar 'rigged' setups.
I thought maybe the PO who did this had a larger (deeper) oil pan or a different motor he wanted to install and need the extra clearance. These washers might have served as spacers for that additional 1/4" (+/-) that he needed. Ron
Ah, the "Shelby" shock tower mod on top applied to the "Shelby" oil pan mod on the bottom.
;D
Have seen this done before for a creative solution for header or oil pan clearance. Lot neater finished look on a modified car that other options
