Marketplace => Wanted Ads => Topic started by: Myfo28 on April 16, 2018, 12:49:59 PM
Looking for 8 each cylinder head plugs part #C6AZ-6052-A for 1970 428 CJ.
Don't have any at the moment. The ones that are roughly the size of a loaded 38 bullet?
They fit all FE cylinder heads. I used to find them on Ford F-series trucks with 360/390 engines.
Just did a quick search on that number and this site says that Dennis Carpenter has some in stock:
http://www.rearcounter.com/C6AZ-6052-A-parts248874.html
Myfo28
I have a extra set of NOS exhaust plugs if needed.
regards.
PHILL BERESFORD
MELBOURNE
AUSTRALIA.
Thanks to you all for helping me search for these cylinder plugs. I was able to purchase a set from Mustangs Ect.
I haven't tried this variety yet, as I still have a tube of the silver stuff (which lasts forever) but you might consider using it when you do your install of these plugs:
https://www.permatex.com/products/lubricants/specialty-lubricants-anti-seize/permatex-copper-anti-seize-lubricant/
If you need to extract these little buggers for any reason later on, you'll thank yourself I think...just make sure you put it on the threads only and not over the tips. It probably would just burn off but neatness/caution counts often times.
I used this flavor of Permatex about 10 years ago on my "smog plugs". I guess I should pull one to see if the Permatex hype is good.
